Volant CAI for 21 Denali
GDragich
Bought the Volant 15954D cold air intake and installed yesterday. Very smooth and excellent fit. Better throttle response and much cleaner look under the hood without that giant plastic box attached to throttle body
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
any pics of it installed.
GDragich
GDragich
GDragich
GDragich
Not noticeable, but throttle is more responsive
TrueAt1stLight
Minneapolis
How is GM with warranty coverage when adding aftermarket parts like this? I’m coming from a long history of German SUV ownership and they can be bastards when it comes to warranty claims when anything aftermarket is installed.
tomgilk
My understanding is if you install the one from the Chevy accessories site it does not affect the warranty, thinking about buying it myself.
From the website- "50-state emissions compliant (CARB Certified) and will NOT void the New Vehicle Limited Warranty. "
GDragich
GDragich
Looks good. Did you have to have it tuned as you do for the GM Performance kit? It is my understanding that the GM Performance kit will throw a service code tell you do.
The instructions say to pull the negative battery cable during install to reset adaptives on air flow. I did and haven't thrown any codes at all. Maybe when Diablo or another puts out a tuner, I can drop a canned tune on it as well.
Dogged
Does it actually pull in cold air or is it basically a less restrictive filter / snorkel? Thinking about this one and really close on the 6.2 performance exhaust (if it only didn't cost so much!)
Hollaway24
Dallas. Tx
Does not void warranty
Dustindu4
Salem, NH
Generally speaking you don't need a tune for your CAI as long as the section that the mass air flow meter is installed doesn't change in diameter. Same airflow, same tune. More airflow and you need to tune it. Which is usually pretty dicey when you want to put 87 in it, the knock sensor doesn't work as good and it will knock. Different tunes for different octanes. I'd like to see actual dyno numbers before I did anything.
Conedaddy
