HiHoeSilver
Away!
Chicago
Getting ready for winter and got blessed with decent weather for Thanksgiving weekend, so here goes...
Water pump has been whining for a bit, which of course prompted a domino effect. I've had parts in the garage for a while now:
AC Delco OE water pump w/ stat and housing
Idler and tensioner pulleys
Serp belt
A/C tensioner & belt
Then some extras to make the whole project worth it... lol
Heater tee fittings (NOT PLASTIC!)
Dexcool, distilled water
Constant tension (OE style) hose clamps and some silicone hose pieces purchased through McMaster Carr.
Since I was replacing the tees at the firewall, I got the Dorman piece with the metal tee by the pump. Then I found this and couldn't resist....
https://www.ebay.com/itm/282998165401
Friday night I drained the system via the lower radiator hose. Then I filled it with the garden hose, ran it for 10-15 minutes, and drained again. I repeated this 5-6 times while I sipped a few brews until it was running clear. Then I pulled the pump and let everything drip overnight.
Saturday, I did the job. Everything went smoothly and according to plan. I pretty much just copied @iamdub on the tees (cutting the rear lines to fit). I used the peices of silicone hose and spring clamps from McMaster. Yes, I put the wiring back where it belongs when I was done...
Then I replaced the A/C belt and tensioner. I used the green Gates belt. Installed the AC Delco OE pump, tensioner, idler, and serpentine. Refilled with new Dex and distilled H2O.
Love the red silicone hoses from Glenn's. The truck is definitely faster now and has exactly ZERO plastic tee fittings in the cooling system! Topped it off with the awesome NBS sticker they sent!
Serp belt
Wait....who are you? What did you do with Nate? Just kidding. Looks great. I want that hose kit but I think I’ll do mine in the black to match all my black braided ones for the blower and catch can. Does it feel faster? :)
mwilson62000
Senior Member
Looks like it’s already peeling? It’s not that hard to order color matched spray paint and clear coat from automotivetouchup and paint them.
Mine are dipped also. I have my color black paint and clear coat. After peeling the dip, how do you recommend prepping them for paint and clear coat? Light sand? Which grit? I think they are painted a light pewter now..
I scuff my stuff with scotchbrite and denatured alcohol, then wash with Dawn dish soap and after they’re dry, clean again with the alcohol and dry wipe again after it evaporates.
NoReverseYukon
NE Wisconsin
Red looks damn good.
Questions for ya - what is the part # for those Dorman T's ? And did iamdub do a write-up for the changeover ?
This sounds like something I should do before they break.
Thanks.
wjburken
Eastern Iowa
Serp belt
Welcome back Kotter!
HiHoeSilver
Away!
Chicago
Thanks.
The tee fittings are from here:
https://jagsthatrun.com/products/traditional-hose-tee
@iamdub's more detailed post is here:
https://www.tahoeyukonforum.com/threads/growing-up-doesnt-have-to-suck.93510/page-68#post-1451010
The Dorman piece i was referring to is
# 626-538
I did not end up using it, as the red silicone kit has the molded tee by the pump instead of a fitting. Win- win.
GJones
ATL
Took off the old scratched tint to prep for darker all around. Never went to do it. Smh
CJ Rodarme
Kent, WA
New kryptonite wheel bearing today, and while I was at it detailed all my wheels and threw my 2” spacers back on the rear. Definitely going to have to get a matching bearing on the passenger side, really happy so far with the quality
Also should be doing the 07+ brake upgrade soon, just gotta find some tires for my 22x12s so I can throw em on once the brakes are squared away.
Bombsquad85
Northern VA
Swapped projectors out for a newer version.
morimoto mini H1 7.0
View attachment 263613 View attachment 263612
morimoto mini H1 8.0View attachment 263614View attachment 263615
I’m a little obsessed with retrofits now. Picked up a set of Denali headlights I’ll most likely throw my 7.0s in to sell locally or on here.
Ugh now I want to swap over to the 8.0s!
Side note :
I spoke with Natr from C&B designs and to have a bracket made up to fit a d2s projector into he denali lamps would run $300
JeffK
