Z71 Suburban Camper
NOSOK
Colorado
Thought I'd start a thread detailing my Suburban camper build. My girlfriend and I have been working remotely since March (and will for the foreseeable future) so our commute is nonexistent. We decided to sell our relatively boring cars and consolidate down to one vehicle more suitable for long road trips and camping. We looked at a few other SUVs and vans/minivans but the Suburban or Yukon XL was really the only candidate. There are compromises to every camper platform, but we wanted something that was both decent to drive around town and reasonably competent off road and in snow.
So we picked up a 1 owner 2011 Z71 Suburban 4x4 with 147k around a month ago. The G80 diff was a must for me, and a 2 speed transfer case was highly preferable. In hindsight we probably would've been better served with Autoride since the vast majority of our miles are on pavement, but the Z71 is comfortable enough and we got a great deal on this.
More to come...
More to come...
Looking forward to all the updates:D
NOSOK
NOSOK
Colorado
First step was to remove the seats and take some measurements. The rear seats (2nd row captains, 3rd row bench) weigh over 200 lbs BTW, so that offsets most if not all of the camper build. Also removed the metal seat mounts and the plastic covering them seen in the 2nd pic. The plastic covers were glued to the carpet, so the removal is permanent.
Important measurements were the length and width of the trunk/3rd row area, as well as ceiling heights.
The rear area is basically 49" x 60". Rear ceiling is ~41" and 2nd row ceiling is ~46".
NOSOK
NOSOK
Colorado
We had also removed the driver side rear interior panels (as seen in the pic below), with the intent to build additional storage, but that idea was scrapped and the panels reinstalled. It would've taken a fair amount of work to get something that looks nice, and we did not want to obscure any of the windows (unlike a lot of the camper builds I've seen on Youtube).
The next step was to decide on the floor covering. Decided to just go with the factory carpets/padding. Any other option (while it might offer more insulation/sound dampening) would require a ton of fitment work as the floor is ribbed. The existing carpet was subject to 10yrs of the previous owner's kids and while it generally looked clean, it didn't smell great. The areas around the holes in the carpet were particularly gross.
So we rented a Rug Dr and spent a day cleaning the carpet, and as much padding as we could reach. Not the most fun, but I'm glad we did it as it feels dramatically cleaner now.
NOSOK
NOSOK
Colorado
Along the way I started getting caught up with some maintenance...these are all DIY except the ATF.
Front diff fluid
Rear diff fluid
Spark plugs and wires
ATF flush
Air filter
There's a lot left to do, but I got the critical stuff done ASAP.
Removed the door mouldings as well since they were falling off. This will probably be the only cosmetic 'mod'.
NOSOK
NOSOK
Colorado
The bed platform is made out of 3/4" plywood. Basically a 47" x 48" piece with 3, 6" tall supports running the length of it, attached with construction screws and a few corner brackets for extra support. The end of the bed is a 2.5' folding section. The main platform is about 1ft shorter than the rear raised hatch area, to give the option (when folded) of sitting in front of it for eating/cooking. I also angled the front legs slightly to serve as a simple backrest.
The bottom is 1/2" plywood attached with a bunch of construction screws. It wasn't strictly necessary to have the bottom 1/2" piece, but I wanted something to protect the carpets and make it easy to slide stuff in and out (skis for example).
Doing some test fits here:
I routed the edges with a roundover bit, sanded everything, and then painted it black with some house paint. I also made some hand holds so I could easily move the platform around by myself while building it.
Here's the folding section. This is attached with 2 door hinges, supported at the edge with some L braces (circled in red) on the corners, and supported at the end with the folding legs. I routed out the depth of the hinges and support braces so they fit as flush as possible. The hinges were attached with a variety of spare hardware I had - mostly 8-32 screws and some loctite. In the future I might attach the hinges with some pop rivets. The L braces were structural so I wanted those a bit stronger. Each is held with 3, 1/4" bolt/t-nut combos.
The folding hinges weren't quite long enough, so I had to add about 2" of extension.
What may be evident in the pics above, and was the most frustrating part of this project, was the bowing of the plywood. I spent several days wetting the concave side of the wood and then adding weights on top in an attempt to flatten it. It worked ok for the main platform, but the folding section still has an annoying amount of bend in it. In a last ditch effort, I screwed a piece of C channel on to flatten it a bit. Might rebuild it, but the bend is only cosmetic.
NOSOK
NOSOK
Colorado
Before installing the platform, we stuffed some full width sheets of 48" Reflectix under the carpet padding as extra insulation and to cover up the bare metal where the seats were mounted.
My girlfriend made window covers for the rear 4 side windows and hatch. These were made with 2 layers of Reflectix, separated by a piece of corrugated plastic to add rigidity and an extra air barrier, and then fabric on both sides. They are slightly oversized so they stay in place once you stuff them in the window frames. Once installed, they're practically invisible outside, and definitely an effective insulator. We're still figuring out a solution to cover up the front windows - we will likely go with some type of curtain that can just be pulled shut. Once that's in place, the truck should black out any interior light.
wjburken
Eastern Iowa
Looks great!
One thing to think about with the plywood is the span covering strength of plywood, particularly sheathing, is typically inline with the grain on the face veneers. Since your platform is 47 x 48, might consider rotating the grain direction of the plywood so it runs side to side.
NOSOK
NOSOK
Colorado
Looks great!
Good to know about the grain direction with sheathing. I considered rotating the legs once I saw the warp, but decided it against mostly out of laziness but also because the 47" side would create a [slightly] larger gap against the sides.
NOSOK
NOSOK
Colorado
To secure the bed platform to the Suburban, I used a pair of heavy duty 12 ga brackets, which were attached to the middle set of rear seat mounts with 60mm M12-1.75 bolts. In the pic below, these aren't fully tightened, since it would jack up the rear platform when they were cranked down. Now that the platform has settled, I should be good to tighten them more.
I wanted to mount it to the truck in 4 places - 2 front and 2 rear. However, the rear mounting locations (the ones that hold the D rings), were basically underneath the legs and I couldn't figure out a clean and simple way to attach brackets. I think mounts on just the front is sufficient, so I wasted a lot of time trying to fit the rear.
We then added a layer of thin, rubber-backed carpet on top of the platform. This wasn't necessary, but makes it look a lot nicer when the mattress is not in there and will help prevent whatever stuff we may transport from sliding around. The carpet was just secured with staples. Spray adhesive would've made for a more professional install but if we want to make any change to the platform in the future, would be very difficult to remove.
The folding design means there's enough room to reinstall the 2nd row seats if desired.
For a mattress we're using a 3" Tempurpedic memory foam topper. I bought this a while ago and didn't really like it so it was sitting around for years. It's perfect as a camper mattress though. If I had to buy a new mattress specific for this, I would've gotten something cheaper. It's a tad wider than the rear area at ~51" across, but squeezes in there with no issue. I'm 5'10" and the mattress is 6' long. If I stretch out fully, my feet will hang off the edge a bit, but otherwise very comfortable. The platform is oversized to allow a few inches of foam extension to be added if wanted.
Only downside is that memory foam gets quite firm when it's cold. It'll soften up eventually from body warmth but there's not much give initially. Sure beats a Thermarest in a tent though.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Cool build thanks for sharing.
NOSOK
NOSOK
Colorado
For food storage we picked up a 12v fridge from Amazon, the Alpicool C30. We went up to Glacier National Park and Yellowstone this Thanksgiving for about a week, and had no complaints about the fridge. However most of the trip was sub 40° so it can't really attest to hot weather performance. Didn't pull much more than 35 watts when the compressor was on. My only gripe is Alpicool describes the fridge as "30L" or "32 QT" but it's more like 28L when I measured the internal volume myself.
The fridge is mounted where the console used to be. There are not a lot of sturdy mounting points there, but I modified a piece of C channel to fit over the studs that hold an SRS sensor. I riveted a few L brackets to the plywood to hold the fridge in place (seats prevent lateral movement) and we have a bungee cord that's wrapped around the fridge handle and attached to the rear bracket. It doesn't move around at all while driving (even under hard braking), but it's on my list to secure this better. Those rubber strips are the same carpet used for the bed platform but upside down.
Not the most attractive without the fridge, but I'm planning to make a small removable storage area and some cup holders. Down the road I'd also like to put the fridge on some undermount drawer slides so it can slide back and give a little more room while driving.
Then on the back I have something I'm not exactly proud of for vertical support, but was rushed to get the fridge mounted last week before we left. I'd like to redo this but the only option for mounts are the front seat bolts and the 2nd row studs (which are a good 8" away).
We got a GoalZero Yeti 500x as a battery backup. I put together an 'energy audit' using a KillAWatt, but I believe it was massively overestimated. I forecasted the worst scenario of both people using a laptop on power for 8hrs/day, running the fridge at 30w continuous for 24hrs/day, as well as running a cell signal booster for 8hrs/day. Debating if we need the 500x as it might be overkill for our needs, but we also didn't charge laptops from it this trip, so I think we'll hang onto it. Seems nicely built.
On the subject of the signal booster we picked up a WeBoost DriveX but ended up returning it. It made a slight difference but not enough to justify a $400 price tag.
I spliced a connector to the fridge charger so it could be used simultaneously with a laptop car charger in the GoalZero. I had to do this since the GoalZero only has one 12v "cigarette style port" and one barrel port. I didn't want to plug the chargers in the AC plugs since going from DC -> AC -> DC is not the most efficient (it would lose at least 10% of the energy, probably more)
How about a Jackery? I've heard they're very good.
Sparksalot
Bastrop County, Texas
I removed all of the rear seat in thecopcar. Most is space for the overland hound. The rest will be where a 35 or 40 L fridge will go.
as far as consoles go, all the various public safety models use a floor plate that’s tied into the front seat mounting points.
ZaZaZazzels
