can you
Young28
The Yukon God
ga
well i mean do you want to lay frame? Do you want it to tuck a big wheel? If yes then yes it will be pricey. If you can do the work yourself it wont be that bad. If you just want to go as low as you can without cutting or notching anything then it won't be as bad.
Narco
Atlanta
and be prepared to give your truck up for 6 months! =)
skyhighsami
Who is doing the work on your truck Trick and what all are you doing to it?
skyhighsami
Awesome, I am having my dually bagged at Silverstar now. It is done now but I can't get it until the 13th. They did it is less than a month. Granted they weren't redoing the inner fenders or anything just 4 link, bags, and 5th wheel connection. Who did your paint work?
Young28
The Yukon God
ga
Well i just got back from the shop and it looks like my bag is actually built off of the LCA. Then the top of the bag is on a bracket on the frame. The bag is right behind the axles.
Sky if your asking me who did my paint work it was a shop in Conyers also.
skyhighsami
What if instead of a ball joint on the upper control arm if you did a heim joint? Would that work better?
vsaravia
