Someone point me to the black lower valance. I dont want to live with the light grey n I don't want to color match it either.
I used black plastidip for mine for the same reason.
I used black plastidip for mine for the same reason.View attachment 261386
I had one painted to match on my 00 then went on a extended road trip while driving from Las Vegas to Barstow we hit a sandstorm in the desert, lol the valance went back to stock grey color, the chrome bumper and headlights got sanded to a nice dull finish because my dumb ass wouldn't pull over and stop. I did have to stop once once because we couldn't see the road got out for a second it felt like someone was throwing sand at your face with a hair dryer. After we got back home it took me a while to get all the sand out that stuff gets in the tiniest of spaces like coffee grounds had to pull off most of the trim and vacuum under the carpet and pretty much anywhere you could see or reach
blueinkd
I saw where someone said the ltz valance was black. I want permanent fix. Not plasti dip or paint. One of them comes black i believe.
Just paint with Krylon Fusion flat black. I have painted all my black plastics with it and it still looks awesome years later. Clean with soap and water and then denatured alcohol.
I ordered all 4 shocks- front and rear. For my Samsung front load washer. I had no idea my washer had shocks until I googled troubleshooting for a shaking drum. Who knew? BTW the reason I put this in this section is it’s a 2002 washer. :cool:
Sam Harris
Rear a/c blend door broke again, for some reason I thought the evap case was $300 which was why I frankenstiened the door last time it broke. (costs $89 so I ordered it)
https://www.getoemparts.com/oem-parts/gm-evaporator-case-88891577
Whoa. This is the case for the rear ac/ heat? Mines a damn mess after I pulled it apart to replace a door busted in there, and I haven’t had time or desire to get it reassembled while in the truck. It’s impossible to get all the pieces lined up. If this is the correct housing, I definitely need to order it!
blueinkd
GJones:(. Come on bro. I have spent enough already this weekend on things I didn't need. Picked up that lower valence and a full 08 tahoe front brake job with new calipers,pads and rotors. Also got new inner/outer tie rods. Probably install Thanksgiving week since I be off. Keep me busy and out of the shopping frenzy!! Probably order some new brake hoses too since I see everyone using SS lines for the NNBS brake swap. 20201101_161443.jpg 20201101_173303.jpg
GJones
ATL
GJones:(. Come on bro. I have spent enough already this weekend on things I didn't need. Picked up that lower valence and a full 08 tahoe front brake job with new calipers,pads and rotors. Also got new inner/outer tie rods. Probably install Thanksgiving week since I be off. Keep me busy and out of the shopping frenzy!! Probably order some new brake hoses too since I see everyone using SS lines for the NNBS brake swap. View attachment 261421 View attachment 261422
It’s worth it! But as others have said bye bye gas mileage [emoji23]
blueinkd
Yeah I was about to order it from Amazon too. Fortunately for me, this truck is parked all week its just an extra car. I been driving it this whole weekend tho! I need to find that dar black lower valance under $100. Seen it online already but ima have to roll with the light gray for now. Didnt get a chance to permanently attached that new lower valance, was just on to check fitment.
Woodblocker55
Got my Borla Pro XS installed. Sounds so good. Hopefully I can get some assistance for a quick video. Got my oil changed and doing my tuneup tomorrow. Also found out there’s some gasket near the front of the tranny is going bad. Can’t remember the name of it for the life of me!
Is that a rotary lift?? I have a in ground one yellow sets in that one picture. [emoji106][emoji41][emoji108]
Sent from my LGL722DL using Tapatalk
mattbta
Frisco, TX
Watched a few videos on passenger blend door replacement without pulling the dash. Thought I could manage, simple enough. Took a gander under there and since I have dual automatic climate control, there's some giant black box right where the video folks were accessing the actuator.
Damn, guess the dash will have to come out.
Bear77
South FL
Are you sure you’re looking at the correct part?
Merch619
