Z71 roof rack on a GMC yukon xl lights ...
Woodblocker55
I ordered some lights from Amazon they will work but it be a bit of cobble job.. is anybody figured out the right GM fog light kit that actually goes in them roof racks. You can see inside they're made for like a specific light. I'm curious if it's just those fog lights those round ones. They go in the front of the Z71.
Sent from my LGL722DL using Tapatalk
mpope2
I used a pair of Hella Marine projector docking lamps on mine. They have a large retaining nut and rubber washers. No need for silicone. I will see if I can find a posting for some more. GM never officially packaged them with the lights because of DOT approval issues in the states I’ve heard. If you pop the covers off, there are thread serts underneath where an OEM set would have mounted had they ever made it that far.
Woodblocker55
Woodblocker55
I'm thinking 3 way switch reverse lights ,off,on .. yes those look perfect what's outside diameter of those do they fit in that little circle.? And clear the hatch when open...
Great find ... [emoji106][emoji41]
mpope2
Sorry it took so long to reply. I missed your question. The Hellas fit perfect in the circle. I will try and post some pics of mine later. The threaded portion that goes through the rack is smaller than the lens itself. I think I used roughly a 1 1/4” hole saw for them
J Mac
Newport News, VA
I used some Blazer driving lights from Autozone. I did have to epoxy them into the end caps so they are permanent. Light output is great.
Old Goat
I used halogens from Wal Mart and made mounting brackets for the inside. Hooked up to trailer light lead with an on/off switch in parallel under the dash.
Woodblocker55
Woodblocker55
shorelocal
BC, Canada
Sorry if this is a stupid question, but where/how did you run the wires through the metal roof? I took the rear caps off my rack and there doesn't appear to be an entry point into the vehicle other than the rack attachment bolts. Am I missing something? Or does it require drilling a hole in the roof? Thanks.
mpope2
You pull one of the rear mounting bolts out and run the wire through the bolt hole, down the rear pillars, then underneath the carpet to the front wherever you are putting the switch.
gmcyukon03
I'm new here, but I'll explain my process from top to bottom in case others want to add lights to their Z71 Rack...sorry if its long...all pics attached.
I restored my 03 Yukon XL and added the Z71 Roof Rack because of the look and I wanted to install lights for when were at the lake at night. I didn't want to cut the hole out and try to fit something that I would need to caulk or seal and not really fit right, and I wanted lights that would mount flush (to keep water out) and to be able to remove the cover if I ever needed to work on them.
The flat area on the cover is very small so I was limited to what lights I could actually install and it's difficult to find 3" round flush mount LED lights, most are square and too big.
After trying a couple that didn't fit or wouldn't look good I found Baha Designs makes great quality lights and I ordered a set of "Baja Designs S1 Flush Mount Wide Cornering LED Light". These lights are VERY BRIGHT and use a simple 2.5" hole saw to install and come with all the stainless hardware and waterproof wire connections. You will need to remove some plastic inside the Z71 housing, but you can use a simple pair of side cutters and it cuts right through...2 minutes.
Wiring: I wanted to control the lights from my dashboard so I found this item on ebay that's perfect "Silverado Switch Panel 2 Toggle BLUE SWITCHES NBS 1999-2007 LED GMC Chevrolet", I bought the 2 switch plate to have an extra switch.
I purchased from Amazon the "Nilight LED Light Bar Wiring Harness Kit 14AWG Heavy Duty 12V 5Pin Rocker Switch Laser On off Waterproof Switch Power Relay Blade Fuse-2 Leads", but wasn't long enough so I used it for all the wiring up front.
I ran my own 16ga 4Cond from the back to front through the cavity under the back seat cup holders then under the drivers side plastic scuff plates...very easy. (Keep in mind I wanted as little splicing as possible so I ran the wire through the hole I drilled in the roof first before running it to the front)
Hole Drilling: First prepare by popping down the plastic inside top trim plate and both rear left and right Pillar Post trim pieces so you can see the wire you run.
Next: inside the roof rack housing you will see a large hole in the base, this is where you drill a hole large enough for the wire at a small angle towards the back.
Then push the wire through and you will see (you might need to pull the headliner down a little to see) it travel down the path where your Pillar Post Trim was (just like the factory intended). You will do the same for the passenger side roof, but run the wire up top across to the drivers side and down to connect it to your wiring with connectors/heat shrinks.
Once done with wiring I used Flex Seal Clear Rubber Sealant to form a mound about 1/2" high around the base/hole of the wire in case water gets under the plastic housing.
I know this seems long, but the whole process should only take a couple hours. Let me know if you need more info.
gmcyukon03
Thanks for the writeup gmcyukon03 ... very helpful. :D
what year and color is your Z71? I'm always looking at what people do with these trucks. I was lucky to find a chrome roof rack and now looking to add the chrome tube steps.
shorelocal
BC, Canada
I actually have an 06 Suburban ... pretty sure it has the same rack at the Z71 ... chrome roof rack rails. I also have the chrome tube steps, but they're peeling and I want to get them stripped and refinished black. That's proving to be a task, finding somewhere that can do it.
gmcyukon03
Yes that's the Z71 package and they only made the chrome for one year 06 that I'm aware of. Unfortunately the chrome on the tube steps don't hold up well. Since mine is a Yukon XL I actually found and ordered a pair of chrome tube steps that have a 45 curve at each end, but the chrome quality should hold up well. They are made by Broadfeet and are 4' oval...should look nice hopefully.
Anyway, I know my truck is not the Suburban version, but It's been restored and part of the family since 05 so adding the Chevy Z71 items makes it a little unique.
good luck with the light and let me know if you have any questions.
Hodmjstone
