What size tire for 24s?
WillRyan
I'd like to know what size tire I should run for 24" wheels on a tahoe at stock ride height.
Can yall post up some pics, tire size, and if you have any rubbing issues?
ICON
Bellingham, WA
Im Runnin 305/35R24 with a 2/3 drop, minimal rubbing. Just trimmed some of the inner plastic. So without a drop you should be fine. Some guys on here have a 3/5 drop and are fine with 305's.
1sikyukon
SFV, CA
Im running 305s and I RUB LIKE CRAZY! it all depends on your wheel offset...trust me best way to go is a 285
Badluck
SE WI
Most run 305-35. Stock height you should be fine with a 305-35 depending on wheel offset. I am running a 275-30 because I like the rubber band look and have lowered the Yukon as much as possible.
BOSS
The People's A D M I N
Dallas
305/24/35 hands down...looks great with the 24s, not a fan of the rubber band
B
denalianyone
NYBlackLade08
New York
For a NNBS, I recommend 295/35/24. The 305 will stick out more because of the fender shape of the newer bodies.
Conor
"Bob's your Uncle"
Seattle, WA
I disagree on that. You can't tell the difference when you look at a 295 compared to a 305. All that depends on the wheel offset. One benefit of a 305 is a little extra curb protection.
W
WillRyan
Thanks yall!
what size offset would I go with so the tires don't stick out? I want it flush with the fender lip i guess
CIATAHOE
Orange County, CA
I would say run 305 35 24, 30 offset, trim the rear plastic, no issues. up front, crank to crank might rub a little.
MonteJ
