Towing Transmission Temp Question
Sdp1234
Southeastern PA
2004 Denali
6.0
3.73 gears
4L60-E/4L654 speed heavy duty A/trans (M32)
173K miles
Pulling about 5k total weight including wood in the truck
I was towing a camper this week. We went approx 90 miles. Highway driving @65-70 mph. Not crazy elevation but a lot of up and down hills.
Trans temp seemed to be a bit higher than normal. I typically see 180 but it seemed to stay between 210 and 220
Is his a concern?
What is the best process to check fluid levels in these trucks?
bigdog9191999
sw michigan
seems a little high to me, to check the fluid, pull the dipstick, it may be time for a fluid and filter change too. taking a look at the fluid can tell you a lot.
if your going to pull regularly it would probably be a good idea for an aftermarket trans cooler.
Are you using Tow/Haul mode?
Fluid level is covered in your owner's manual, available online from GM, like this from an '04:
Rocketman
I’m using tow haul mode and I’ll get on that aftermarket cooler in a couple weeks
Thanks
There’s lots of write ups on installing the Tru Cool 40k in our trucks.
S33k3r
Dallas, Texas
There are also videos on installing the Tru Cool, along with various forums (and their members) who sell add on kits to make it even easier to install (but bring $$$).
S
Sdp1234
Southeastern PA
Update... I needed to tow again the next week and I was uncomfortable waiting for a cooler. I installed the only one I could get. Not anything as good as the Tru-Cool but it kept me below 180 rather than around 220. If I have to go back and replace with the Tru-Cool it will be easPictures below
S
Sdp1234
Southeastern PA
Next I needed to address the tapping I started hearing. Manifold bolts rusted off. Added this
Also received my headlightlight kit yesterday.
afpj
Looks like your power steering cooler is about to go...
S
Sdp1234
Southeastern PA
I forgot about this and the cooler went last week. I replaced it (even chose the ac delco part for more money) and the new coolerline is leaking. Can I bypass this for a few weeks until i get a chance to take the cooler out and take it back?
Mudsport96
40.923,-89.488. Illinois
Not sure what the line size is, but if the transmission cooler kept temps down with the load you had, and the load is the usual you will haul...you are probably fine with it.
Also what cooler was it?
rockola1971
Indiana (formerly IL)
Agreed. 220 deg isnt nothing to sweat bullets at BUT your tranny will last alot longer with a tranny cooler installed and temps kept below 200deg. I not only recommend them for towing vehicles but even daily drivers. They are cheap compared to the cost of a rebuild every 125k.
johnsonwillie199
