New system
tilghman
Fayetteville Arkansas
I added a kicker zx 750.1 amp to a l5 10' solobaric with 0 gauge tsunami wiring and stinger 300amp fuse and stinger braided rca's to my pioneer premier 600USB let me know what you think also need to make a small amp rack any ideas? I went with the 750 so i can upgrade subs later
T
tilghman
you dont need that big of wire for that small of a amp.....but if you plan on having a bigger system then you will be good for when you do it..
yea the the guy i bought the amp from threw that stuff in for free so I used it.But yes it is big but i dont think too big could hurt only to osmall right?
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
a simple carpeted plywood board, and turning the amp 90 degrees will greatly improve the cosmetics of the install.
Running all the wiring under the carpet will help a lot too.
Are you going to use Allen head bolts and T-nuts to mount the amp?
I think it would really clean it up, and would make things easier to maintain down the road.
You can find them at ACE hardware, Home depot, Lowes etc.
I used them last time to mount my amps and it was way way easier... once you were done predrilling.
MOBmentality
Has a $25,000 Punch
hahaha holy effin wire!! lol good shit! room to upgrade
thehoe92
fo sho
The916
that ground does not look good.
looks like just the seat frame and not the actual car frame
T
tilghman
Thanks eagle .allen head bolts and t nuts? what size i really want to clean this up i just did a rough install to get an idea of what i need
Where did you guys ground your amps? not many options back there
Eagle
EL PASO, TX
thehoe92: the seat frame is = chassis because it is bolted in. Plus looks like that ground is on the seat bolt= chassis.
T: on my PPI a300 I think it was 1/4-24 or something? Easiest thing to do is just go thru them and find one that:
a: has a head big enough to retain the amp,
b: a shaft small enough to go thru the hole
c: a shaft long enough to go thru the amp and the mounting material
d: pick out T nuts with the same thread pitch and size.
then you drill the mounting holes, put the t nuts in, Clamp them into the wood.
T
tilghman
Thanks eagle sounds good !! what about after the amp is on the wood best way to attach this to the body under the seat? gonna start look for materials tomorrow
thehoe92
fo sho
The916
it doesn't have the least resistance like you could if you went directly to the bolt that holds the seats to the frame
just saying if you start seeing electrical problems, have any type of interference, or your amp is going into protect change that ground
a good ground
if you want get a DMM and set it to OHM and check the resistance between the bolt and the frame of the seat
EdgarCervantes
yuppp that ground is ******.... listen to thehoe92 if u have a bad ground the amp will also start heating.. heating=lost power now go get a good ground!!
matt14
san leandro,ca
I cut two pieces of mdf and screwed one into the floorboard, then the other from the amp to the mdf that is already mounted so that it would clear the seat braces.Did this on both sides of the amp. My amp is pretty big though. Like stated above, run the wiring under the carpet for a cleaner install. I would also recomend to ground it to the frame. I did this on my amp but had to run a long ground wire.
thehoe92
fo sho
The916
keep it as short as possible to avoid noise interference
if your speakers whine as you accelerate you know what I'm talking about thats alt/engine noise and thats the ground being transmitted through your RCA signal.. usually the shield on the RCA will protect it but not all the time
the BEST ground you could do would be a full run from the front battery to the back because that would ensure a full circuit
I know this may be a little much for what you are running but its just little thing to remember when you start to get bigger.
T
tilghman
upgraded System Needed box advice
i replaced the head unit with a AVH-p7500dvd with Xm back up camera and navi.Also junked L5 10 for 2 solo L5 12's check it same kx750.1 amp but it pushes the so hard its beatine the anchors out of the speaker screw holes. Should I replace the box or any way to fix this right? i still have the amp to mount correctley and better ground and hide wires and make it sleek just curious if anyone has had this problem with factory kicker boxes
briannorris
