Sunroof Accordion thing on sides...?
DjJayFrree
DJ to the Stars
East Bay Area RI
No idea how else to explain ti but the thing that is like an accordion when you tilt the roof... On the passenger side is has disconnected from the top of the sunroof. Is this an easy fix? I can post a pic if this makes no sense.
thanks!
mr tahoe
It does make sense to me and i think you just push it back in, i think your talking about the plastic cover that covers the mechanism on the sides
Stephenprzy44
thanks!
thanks!
Hi,
This is completely off subject to your question but I see that you have a pioneer navigation in your truck with apple carplay. Is it a good navigation setup and was it plug-n-play? I am looking to put one in on my 2010 chevy tahoe which does not have navigation. I am looking at kenwood because I hear good things about them but I'm still looking. Any suggestions?
Thanks, Stephen
DjJayFrree
DjJayFrree
DJ to the Stars
East Bay Area RI
LOVE my nav... if I was doing it again I'd spend the big bucks on the one flatdale was selling tho... I don't use car play that much because the USB port doesn't charge the phone as fast as the one in the center console if that makes any sense. you have to have the phone plugged in via USB (as far as i can tell) for car play to be enabled (stupid)
Stephenprzy44
Yeah I'm looking into kenwood because I hear good things about them but also looking into pioneer. One last question, was it hard to install? Thanks!
olsonpaw
thanks!
Hi - did you get this fixed? This happened on my 2016 Yukon XL - dealer wants $200 to fix this. I see I can buy the part for $35. Can I really replace it without taking apart the sunroof?
RST Dana
OH
If you original piece is only loose, you can re insert it. You can add some glue to the slot if necessary.
olsonpaw
I had to remove mine completely (or i did) because it was preventing the sunroof to close. Is there anyway to re insert it without taking anything apart?
RST Dana
OH
I was able to re insert it on my 13 without issue.
ddann19
Western Illinios
We just noticed that our glass is off track. Wifey came home from getting groceries and said she opened the sunroof but it was all jacked up. I think that plastic cover was not seated properly and when the glass moved back it pulled itself out of the track. I couldn't get it back in. I had to help force it close just to get it closed, it already has a date with the shop Friday. So not sure what is going on with ours but will let you know what the shop says.
TejasPitt
