Thouse
Hey guys long time no talk. I polished my headlights the best I could by hand without drill and put in some brighter headlight bulbs.
Anyone have a recommendation for a rear floor covering on the cheap? (Rubber mat style) My hoe has no third row so it needs to be bigger.
Thouse
IIRC. It was 01 or 02 they were still installed. My ‘03 doesn’t have it so I bought the kit.. still need to install it tho.. [emoji13]
I would be interested in that but I am not that handy... so if it’s complicated I’m probably not going to be able to do it ha
Thouse
Also today- general cleaning and trying to get this dash mat to lay flat before I put any sticky Velcro on my dash. Do any of you guys run these dash mats?
The A pillar passenger side trim was falling down. This clip was the culprit. I have nothing to clamp it down while I try to glue it so I am trying to glue the shit out of it without clamping. it’s worth a shot before I’d buy another trim panel.
C621BB86-269E-471E-BC46-D0B9C442F9E2.jpeg F1DBEE7C-F5C2-4EB2-8F01-77E4D0545C60.jpeg
It’s simple, you just need to score a razor knife along the lines in the hvac housing and cut the plastic piece out, slide the filter in and then put the cover on and put a screw into it.
Found on Amazon but says it doesn’t fit my truck. Thought maybe I was looking at the wrong item
Pretty sure it fits, read the reviews where they talk about that. Here’s a YT video with links at the bottom for the Fram filter and the Dorman door separately. I did this to my 08 Silverado.
rgosart
I used a big rubber utility mat from Lowes. Cut it to fit.
Mezzo
Finally got the suburban up and running today,got a new 145 amp alty put in and some USB outlets with a volt meter installed, took it for its first maiden voyage in 4 months and it drove like a dream,could use some new brakes,i missed this thing.
Phlipnstik
