Fog lights
Bamajake95
First of all I'm not sure if I am even posting this in the right place. If not could an admin please move it to the correct place.
Secondly I have been off the forums for awhile so forgive me if I'm not using the correct terminology.
Now onto the point I have a 07 yukon sle, that does not have fog lights. I am going to add fog lights(already have housings and bulbs) and am wanting to be able to buy the factory dash switch and use it. But I need to know if that will work or what I will need to do for it to work. Nextly I need the wiring for the fogs with the relay and all to wire them in is there a "gm upgrade" or is there a part that someone can reccomend?
I hope those questions make sense I could use any and all help that is possible.
Thanks in advance!
Sent from my SM-G975U using Tapatalk
juan_carlos__007
Now onto the point I have a 07 yukon sle, that does not have fog lights. I am going to add fog lights and am wanting to be able to buy the factory dash switch and use it. But I need to know if that will work or what I will need to do for it to work. Nextly I need the wiring for the fogs with the relay and all to wire them in is there a "gm upgrade" or is there a part that someone can reccomend?
Thanks in advance!
Harbor freight [emoji1787] has some really bad *** 3" spot leds and they sell the harness with relay and switch. Somewhere you should be able to find coupons for them. I guarantee they're brighter than any stock fog light out there.
Sent from my NX629J using Tapatalk
kbuskill
NE. FL.
There is a complete kit that you can order that comes with everything you need including housings, wiring harness, switch, etc.
I don't have the part number but @915_Tahoe could probably help you out with that.
I know some of the PPV guys have tried to use the kit.
Bamajake95
Bamajake95
Awesome that is what I'm looking for. So far in my research all i have been able to find is "universal" kits. If its a factory upgrade kit then that is what i want! What is the best way to get in touch with him?
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
If you can provide the last 8 of your vin#, I can find out tomorrow when I get in to work.
Bamajake95
Bamajake95
I will get it in the morning and send it to you. I appreciate it so much!
915_Tahoe
HELL PASO, TX
GM#19157652 LAMP PKG, FRT FOG (INCLS LMPS, HARN, SW, INSTR) (INSTALL TIME 1.00HR) 2007 - 2013 $230.00
Discontinued through GM
LAMP PACKAGE. DOES NOT REQUIRE PROGRAMMING. ALSO PACKAGE INCLUDES THE HARNESS. WHICH IS NOT SERVICED SEPARATELY.
Bamajake95
Bamajake95
Thank you again so much!!! Exactly what I've been trying to find.
HeavyHoe03
