BaMaDuDe87
Bama
Does your AM/FM reception suffer when you do the Esky antenna delete? If so, how much?
Thanks!
Absolutely, but like said if you live in a big city, you prob won't notice it much. If you live in the country or on the outskirts (away from transmitting towers) you will notice it.
Sent from my Pixel 2 XL using Tapatalk
Mezzo
So after buying the esky rack for peanuts,im honestly not sure if i should delete the Z71 rack on my 03 Hoe and put it on,but im conflicted since i aslo love the Z71 rack.
BaMaDuDe87
Bama
How hard would it be to install the esky antenna? I get fine service on my escalade. I know I have heard of some people running wire up in the door seal or some such deal in order to act like a bigger antenna.
Running a wire up the door didn't help me at all. I played with it (the length, different ways of running it (up the door, across the windshield, etc), wire touching the body, wure not touching the body, different ways of grounding the wire to the antenna base) for about 3 months before putting my antenna back on. I live closer to the country than city AND had an aftermarket radio, so my stations were all but completely MIA about 85% of the time. Couldn't do it. Looks good, but function, for me, was not acceptable.
Danny3737
Hiding an antenna from being able to see sunlight is like hiding your WiFi router in a closet. Sometimes it works great and sometimes it doesn’t, it depends on how close you are to the signal and how much strength the the transmitter is putting out. I’ve used antenna boosters in the past and some of them do work pretty well.
Sam Harris
I might do this.. tbh, this is the only reason I haven’t deleted mine yet.. I have the Esky part sitting here waiting...
This looks pretty good too..!
Bingfu Car Hidden Antenna Car Stereo AM FM Radio Antenna Car Windshield Window Glass Hidden Adhesive Mount Antenna Aerial for Vehicle Truck SUV Car Stereo Audio Radio Head Unit CD Media Receiver https://www.amazon.com/dp/B07TT54W8Y/ref=cm_sw_r_cp_api_i_cebuFbKH4HTAM
HiHoeSilver
Away!
Chicago
Are you an urbanite, suburbanite or ruralite (is "ruralite" even a word?)?
Suburbanite. I have always been a radio guy in the car (mostly AM, even), so i am able to compare the factory setup well, as I have been using it for years. The AM suffers a tiny bit, but is still fully functional. I can honestly say that my FM reception is exactly the same.
moto
