HVAC only works on high setting..
PATR1NYC
Empire State of Mind
in my 96 hoe..when i try to change to low or any other settings-no air is coming out-only when i put it on high- air starts coming out-any idea why folks?
thanks in advance
97srad750
Lexingon, SC
There is a blower motor resistor behind the glove box that needs to be replaced.
97srad750
Lexingon, SC
nice-thanks for the reply!
is that an easy fix? parts should be readily available-no?
Yeah it's pretty easy. It should just be available at Autozone or OReillys. Take off the glove box, the black plastic shroud that surrounds the blower motor, and you should see it
Jackalope
Angleton, Texas
yep. I've got the same problem, I just haven't fixed it yet because taking everything out is a PITA. But replacing the resistor should take care of everything.
ZaZaZazzels
