Control Arm and Ball Joint Assembly
mnjeepmale
I'm wanting to replace the upper and lower ball joints on both sides for my 15 Tahoe LTZ. Looking at just replacing the CA that has the ball joints.
When looking at Moog brand I see different options for CA. What is suggested for CA on this vehicle?
GMT800 2005 Tahoe Z71
Navy Supporting Member
When I look at the AC Delco arms, preferred, it just wants to know if you have aluminum steering knuckles.
You will have to either dig in there and scrape the knuckle with something metal and see if it is aluminum or know what RPO code in your glove compartment says.
I did some searching and found that the Z71 package has the aluminum arms and steering knuckles. If you do not have the Z71 package, then you have the stamped steel arms.
Front left lower: https://www.rockauto.com/en/moreinfo.php?pk=6269505&cc=3307627&jsn=925
Front Right lower: https://www.rockauto.com/en/moreinfo.php?pk=6269508&cc=3307627&jsn=926
Front left upper: https://www.rockauto.com/en/moreinfo.php?pk=3247521&cc=3307627&jsn=927
Front right upper: https://www.rockauto.com/en/moreinfo.php?pk=3247161&cc=3307627&jsn=928
These are the less quality Professional grade.
The OE quality grade is more expensive and can see them at RA where I found these.
M
mnjeepmale
It shouldn't be the Z71 package. What code am I look at on the label in the glove compartment?
No need for the RPO code if you don't see a Z71 badge on your rig. But the RPO code Z71 would be on your RPO code sticker inside your glove compartment. If you look and see no Z71, then you do not have that option.
greenhornet
Ontario,Canada
When I replaced mine they were Aluminum but the factory replacements are upgraded to tubular steel,no more Aluminum ones.
M
mnjeepmale
I have the 1LZ package.
Ok thanks for this information. So look at steel CA.
Sent from my SM-N950U using Tapatalk
Are you wanting Moog or AC Delco? I will look them up for you. The ones I looked up are not the best quality AC Delco, like oe is, but if that is what you want, the part numbers are there to order at RA.
M
mnjeepmale
I'm leaning more towards Moog. I think Moog are good parts.
M
mnjeepmale
Thanks for the info. Do you think it's worth spending a little extra for the CK series(problem solver)?
The problem solver items are for a rig that has trouble getting the alignment within specs after parts replacement. Those would be needed for a rig that gets an alignment reading before the parts replacement and sees that even with new stock parts the alignment will not be able to be adjusted to spec. Usually with weird size tires or known wreck damage but no frame repair has been done. Lots of times they are not installed till after new OE parts were installed and cannot get the alignment in specs.
QDaddy
I've done just the ball joints and screw that. My last two were control arm assemblies and I never looked back.
M
mnjeepmale
Well looks like I have aluminum CA after we put the truck in the air to replace the parts. Now to find the correct Moog parts to order.
91RS
GA
They're actually stamped steel. The ball joints last much longer on the stamped steel ones by the way so it is an "upgrade" in that aspect over the aluminum ones.
M
mnjeepmale
Well if you have aluminum CA it's replaced with stamped steel now according to the dealers that I spoke to.
They suggest to replace the brake hose too.
ibarra503
