what happens with the fuel pressure when/as-it dies?
the dying symptom is not consistent, it kinda only comes along after heavy hot drive. Should be able to recreate that over the next few dayswhat happens with the fuel pressure when/as-it dies?
do you know where that valve is?If I remember correctly theres a check calve in the fuel system that keeps the lines full. If its bad the lines drain out and it gets hard to start or the fuel lines may have been moved with the trans work and they are near a hot spot and the fuel is boiling in the line.
I am very leery of problems that “just go away”.I do hope it is ok now and not going to give you problems. Please do tell us if you find more info later that points to the original problem because that info is shared and used by all members here. I always like that I can pin point the exact problem and replace a part and know that I can drive my rig with confidence. In this case that may gnaw at you, I hope not though.
IT’s BACK........
After a while of solid driving with no issues my Yukon died again yesterday in a similar way to before.
Been driving around the mountains, filled him us with gas, drove on highway for 20mins, exited freeway and then died and no restart, lots of cranking but no start. Left him on the side of the road for 2hrs, returned and started first time!!!!!!
Interestingly, I have been freewheeling down the mountain recently and when I do this the fuel gauge drops to zero......I have to think this is connected to the same issue.
Going to replace the fuel pump unless anyone has other suggestions?
BTW, any suggestions on what I should be paying for that job to be done? I would attempt myself but I have no way of getting the car up to access the tank
NBS?At this point it would be less expensive, in the long run, to sell the rig and get a dependable NBS........just kidding but I hate intermittent problems. The newer the rig the more I seem to see them on 2007 and newer.
I do have a pretty good Tech to take it to, they have done most of the minor work in the pastThe price would depend on the shop that fixes it. I am now assuming you don't already have a shop you take your rig to. The dealer will be expensive, with a capital "E". I have an independent shop that I personally know the 2 techs and they let me supply my own parts. This is if I don't do the job myself.
