I think I'm gonna add oil pressure, volts--gotta see what else I have to throw in there. I have a few laying around.View attachment 251916 View attachment 251918
I used a Glow-Shift pod made for the NBS Pickups and SUV’s, it fit perfect with zero ******* around for my boost/AFR gauge. I just don’t understand why you want to duplicate gauges you already have like volts and oil pressure. The stock gauges are accurate. Now if you need to add a wideband or AFR gauge that’s one thing but what you’re talking about is a waste of money imo.
I'm paranoid about the oil pressure, since this and my van's oil pressure went to 0. I just want to be cautious, that's all. I already have all the other gauges in my parts stash. I'm not interested in doing an AF gauge. We actually talked about that one before. I don't really care about the volts, but I have a gauge for it already.
It wasn’t your gauge. It was your oil pressure because due to a spun cam bearing. You’ll still be using your stock sending unit so I still don’t get it. Carry on.
That was gonna be another question later on. Where could I pick up a pressure reading--other then the factory sender.
Scottydoggs
NJ
Scottydoggs
NJ
Nice. Looks like you're in good hands.
for sure. and i literally just got the your cars ready to be picked up call. not a bad turn around. i dropped it off fri 7-3, so it sat for 3 days, so really a 4 day wait. now to figure out how to get there again lol if its raining all day im off work, makes it easy, if no rain ill have to take sat off and go.
GJones
ATL
eohat
In Torque We Trust
Mike @ Altitude 5,280 ft.
There’s an oil pressure tap that you could use on the driver’s side front of the block. ICT Billet makes an adapter to 1/8” NPT if you need it. It’s popular with LS swaps to run the factory oil pressure sending unit/gauge on older vehicles.
https://www.amazon.com/Engine-Adapter-Pressure-Sensor-551172/dp/B015NFNC10
Thx :waytogo:
This seems to be a good set also.
https://www.amazon.com/Master-Adapt.../B075RW533W/ref=psdc_3097827011_t3_B015NFNC10
CKendrick
