Cabin filter from factory or retrofit?
aaronb
I have a 11 yukon xl and see differing info out there. Is there a cabin filter from the factory installed or will I only have one if the retrofit was done? If not from the factory, is the retrofit doable by a dyi’er? Anyone do a how-to?
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
GM#22759208 FILTER KIT, PASS COMPT AIR (DOOR W/ BOLT) FILTER separate
$44.07
Will have to cut out the plate to install filter, really easy. a good box cutter with a new blade will do the job.
Derick
Indy Suburbs
You can pick up the retrofit kit and filter at Rock Auto for $44. It is a fairly simple job to perform. You will need a sharp utility knife blade. Many folks here, including myself, have successfully performed this retrofit.
DORMAN 259200 {#22759203, 22759208} Includes Plastic Cover Plate
https://www.rockauto.com/en/catalog...ditioning,cabin+air+filter+retrofit+kit,50209
If you get the other Dorman kit with the charcoal activated filter, it's a 39 dorrah.
curbud
