Isn't the Goodyear tire the best option for a PPV?
Lightning 95
After going over and over all of the different tire sizes, and wheel option up to 20 inch, I've decided I'm going to go with a new set of 265/60-17 Goodyear PPV tires. I'm currently on 255/65-17 Michelin X ice tires looking for summer replacements. I have all the equipment to change tires, including a Hunter road force balancer, so I won't have to buy wheels just yet. I liked to Firestone PPV's I had, but they were badly out of round, plus they are stupid expensive. I believe the new generation Goodyears have been tweaked a little. Found this article explaining how they are designed exclusively for the Tahoe PPV.
http://www.hendonpub.com/resources/article_archive/results/details?id=5956
I like the goodyears, the rsa, eagle, eagle sport are all V rated, they stick to the road like glue even in heavy rain, can't say how well they do in snow it doesn't snow where I live. I get good mileage out of them, exactly how much I don't know I put a new set on my nbs about a year before I sold it, it probably still has them on it, I bought my 2012 with a set on it already and I have put 20k on them and can't even tell the difference. there quiet no discernible road noise even after getting some wear.
Lightning 95
Lightning 95
After reading the link I posted above, I figured out that most online sites are selling off the 265/60-17 RSA tire in the older discontinued model, and not the newest model, which are out there if you look, for a few dollars more.
They look identical, but they are 2 different tires which they apparently modified in 2015 for the new generation PPV.
Old number 732301500 around $800 up to $1100+ per set of 4
New number 732523500 around $1100 per set of 4
Lightning 95
Lightning 95
Has anyone out there had their PPV wheels powder coated in black chrome?
indigent
Central Texas
We replace the Goodyears on ours with the Firehawks after the set from the factory is worn out. I'm sure it's the older model tires that they were replacing. We found that the Firehawks were stiffer tire but yes, I can vouch for the out of round issue.
I have a '15PPV at work and my tires suck once they're out of round. It's like rolling down the road inside a coke can with pennies inside of it the damn thing rattles so bad.
RichardCranium
Mebane, North Carolina
The grip is awesome on the RSA's, no doubt. IMO, that is the only thing awesome about the tires. Agencies that buy these trucks put them on for that reason and that reason only, these certainly aren't a tire intended for mileage or ride (its the sacrifice of a speed rated tire). If they are meticulously maintained (rotated, balanced) along with any other maintenance that contributes to tire wear, you can make them last a decent amount of time. But having come from a fairly fresh set of RSA's on my PPV when I purchased it, I will never look back at them or consider running them again. I jumped up to a 265/70, which opened the choices to a wide range of tires. I followed a fellow forum members recommendation and got Continentals, I honestly could not be any happier with the ride. Mind you, I lowered mine further than about 2" more than PPV height as well with a Belltech kit, and my PPV still rides better than PPV height with the RSA's. Can't knock that at all.....
iLikeEggs
Potato!
Oregon, USA
Mine came with the Good Year HT load range E's on it. I ran them for a while until they wore out. I replaced them with Michelin defenders, also load range E. It's been a good tire. They can take a curb like it's nobody's business. I've got about 40k on them now and they will probably reach 60k.
GranPrix
Any reason why the swap to the Firehawks over the RSA?
RED TAHOE LS
Rossville, Georgia USA
Like Matt stated......They can take a curb like it's nobody's business. I've got about 40k on them now and they will probably reach 60k.
I just don't think you can beat Michelin tires, they have all the guts for a safe/great/smooth ride with minimum weights too balance.
David g
........:2cents:
RCMPTahoe
What tire size do you have?
I am looking for LT tires for my 2012 PPV with load rating E and cant find them from any manufacturer. 265/60 R17.
PPV12HOE
NC
Discount Tire Direct has the Eagle RSA for $156 right now...
Peacock
Buffalo,NY
Wonder what year they are ? I was my go to garage for inspection and a guy unloaded 4 tires bragging about the great deal he got until my buddy pointed out that 3 of the tires were from February 18 and the other was January 19.
PPV12HOE
NC
I couldn't tell ya that one...
Peacock
Buffalo,NY
That's the tires I have on this North Dakota PPV with 74k miles, that I bought in February, mine are dated 18 and have dry rot cracks in between the treads on the two rear tires.
madmanjustice
I just put a new set of Khumo Crugens on my PPV. Stock size, I really like the ride.
RichardCranium
I still don't see any reason for someone to put those RSA's back on. o_O Going up in sidewall size made one of the biggest differences for ride, when I switched over the Continentals. I actually dropped width and profile a little this go around when I moved to Michelin XLT's. You get what you pay for I suppose, these were just under $200/ but the ride is even better than the Conti with the taller sidewall.
1BADI5
DMV
I personally only run Goodyears, BFGs or Nitto tires.
My PPV came with some cheap china garbage tires. I replaced them with Goodyear Eagle Ultra Grip GW3 tires in OEM size (265/60-17) amazing in the rain. I got them from Sam's club when they had them on sale for $52 ea.........wish I have bought several sets at the time; not theyre upwards of $200 per tire.
trailblazer
We run Finnish or Russian made Nokians up where I work. WR-G3’s or WR-G4’s “All Weather” tires. They outperform low-end snow tires in the winter and work great on dry pavement in the summer heat.
Hodmjstone
