Plastic Cover On New Actuator?
lumberjack890
15868318482923801884431415033050.jpg 15868370774221913304255334884012.jpg Do you remove the white plastic piece of the actuator or leave it as is. Just trying to be as careful as possible and not break it by accident
L
lumberjack890
leave it, that's part of the actuator besides you couldn't get that off or out without opening it up and then you would see it is part of the gear inside
Thank you! But i have this metal gear but that prevents me from putting this new piece in. It seems to be attached to plate behind it. What's up with that?
the gear is notched, you may have to turn the gear to match up with the notch on the new actuator, then it will slide on.
Mode door actuator ( under steering wheel). Part # is 604-106
The white plastic piece us preventing me from putting it back in place.
it's possible you might have the wrong actuator if it does not match the old one 100%, there is no actuator under the steering wheel btw.
L
lumberjack890
Might be, but every other actuator I find has that plastic piece on it.
My bad lol. The actuator is above the gas pedal.
That metal piece is what's blocking me
View attachment 244659 That metal piece is what's blocking me
i see what's going on now, take a pair of pliers and pull that metal piece off that you show sticking out in your photo, then your actuator will go on, looks like the old actuator just came completely apart and left the gear behind. go easy and wiggle it off you don't want to break that piece that it is attached to.
L
lumberjack890
Yep got it off. I've put the new piece on and I finally have air blowing through after five years! This forum is absolutely fantastic!
Off topic but is there a blower motor in the rear that controls the rear A/C vents?
yes there is 2 actuators, a blower motor and a control module, that rear blower motor may also have a resistor, if you suspect the rear blower motor is out you can put 12v to it directly to test it.
L
lumberjack890
Yea, that one is pretty easy to diagnose. Doesn't even want to come on when I try. Well guess there's my next fix
Drewphil
