BADRIDES
- Joined
- Dec 18, 2015
- Posts
- 1,825
- Reaction score
- 1,278
Let's see a side shotYou have to swap the glass for the mounting holes to line up. I have one on my 06.
Right DA90, you missed the question, will the brake light line up on the Tahoe glass, so I can tape it down vs. using the mounting holes? Trying to avoid buying a nearly identical glass if the mounting holes are the only differences in the two.You have to swap the glass for the mounting holes to line up. I have one on my 06.
@Da90 Did answer your question. you must use the glass from the esky. the esky glass has a flatter surface for the mounting holes.the tahoe glass is missing the center top cause the lamp mounts to the cab.Right DA90, you missed the question, will the brake light line up on the Tahoe glass, so I can tape it down vs. using the mounting holes? Trying to avoid buying a nearly identical glass if the mounting holes are the only differences in the two.
What he said^@Da90 Did answer your question. you must use the glass from the esky. the esky glass has a flatter surface for the mounting holes.the tahoe glass is missing the center top cause the lamp mounts to the cab.
Also the appliqués are different on the sides. Not just the look but they way they line up with the brake light and glass.@Da90 Did answer your question. you must use the glass from the esky. the esky glass has a flatter surface for the mounting holes.the tahoe glass is missing the center top cause the lamp mounts to the cab.
Esky covers?Thanks 915_Tahoe, for that confirmation. I guess there's no shortcut on this mod... Well I got pretty lucky otherwise today and scored Denali vent covers that are already color matched black. A little clean up, polish and maybe I get away without painting them. Also got a Denali rear bumper that is charcoal vs. black, will check it out to see if I will get it painted.Better looking than stock chrome...![]()
These came off a Yukon Denali...maybe someone got them from an Esky first.Esky covers?
YupThese came off a Yukon Denali...maybe someone got them from an Esky first.
What size tire on the 24's?I am still working on finishing a few things. I am going to color match the bumper and top pad.
Yup.These came off a Yukon Denali...maybe someone got them from an Esky first.
