2009 Yukon Denali XL Heated seat problem
BH1989
Hi everyone, I realize this has been discussed in the past, but I haven't found an answer yet. My 2009 Yukon heated and AC seats do not work anymore, Both driver and passenger. the passenger motorized seat does not work either. I have looked at the common item as I found here on the page as the connector under the passenger seat. My connector is fine, no burning or melting of the plug. I have also checked the circuit breaker under the dash and swapped it with a known good breaker. Still nothing works.
1st questions, is there a fuse for the CCSM module that could have blown? (I did not see one listed in the manual)
2nd question, Could the module itself be bad? If so is there a way to test or should I just replace ?
Let me know if I may be missing anything, But I follwed through many of the threads already started about this issue and none of them seem to help my situation.
Thanks!
Yes, proper diagnostic tools! Welcome Bobby! There are lots of modules that interact with the heated seats and determine whether or not they work. You need access to the internal trouble codes that are stored in the BCM. Do you know anyone with a Tech-2 or other bi-directional scan tool?
You can buy your own Tech-2 to work on your truck or get the VXDIAG NANO that comes with the software to run on your laptop do you diagnose this properly without guessing or throwing parts at it.
B
BH1989
I have scanned the BCM ( I have access to a Snap on Modis,forgot to mention this before) No codes. I also need to add that a week ago, when I unplugged the connector under the pass seat, the seats began to work for about a day. Then stopped again all together.
That's very odd. If you can use the Snap-On again, get in there and test seats, power them up through it and see what happens.
mikeyss
Longmont, Colorado.
Thanks!
I had something similar and found another connector that comes loose and burns. It's under the passenger seat still, but on the back side. Those terminals come loose too and make the pass seat and drivers heat/cool not work.
B
BH1989
We did give that a try, no dice. Seats still do not heat/cool and pass seat wont move.
B
BH1989
Is there power at the plug you disconnected? Do you have solid grounds everywhere?
I will check for this, I have not pulled the wiring diagram yet to see which wires have power
B
BH1989
View attachment 241284 View attachment 241287 View attachment 241288
I Found this connector to be somewhat of the problem. I haven't had much time to dig into it, But I pulled it apart, no burns or wear. Although when I re connected it, the seats started to work. I will pull it apart more this weekend and figure out the real issue. Thanks for the input here.
mikeyss
Longmont, Colorado.
My problem was specifically with the black wire, the thickest one. When mine was messing up, I jiggled that one and everything worked again.
petethepug
Michael
SoCal
Cool, I mean heated ... lol Didn’t know the Denali has the option to get ball coolers in 09. I was
doing a little digging to see if I could determine when GM went from cooled seats to ventilated.
1) Someone correct me, but it seems 2011-12 is when GM discontinued using a TE (thermal electric) unit to cool the seat air vs. ambient air only.
2) Again, someone correct me if I’m assuming wrong, but the cooled seat option means there’s no resistance heated mat like the conventional heated heat, right? Early cooled seats use a TE to cool the air and later seats use ambient cabin air. Both early and late versions use the TE to heat the air for the occupant.
Back on topic though. Some of the failures in the heating/cooling functions come from the switch in the door. Water gets in there and kills the circuit or can also cause the seat to randomly turn on and heat.
johns2008
when one or more of you mention A/C along with heated,, i'm not sure i have A/C seats how do i find that out and is the heat not working issue to resolve the same way as one with ac?
jk6062
