2008 Tahoe..Transfer Case Control Module / 4X4 issues
Picknz
Sup fellas/gals,
Im having trouble figuring out the issues that’s going on with my 08 LTZ hoe. I searched all over this forum and couldn’t find my answers. I recently got a “Service 4wd” message; none of the lights on the Transfer Case Selector ever illuminates (no matter what position the key is in). I later went to Orielly to see if any codes existed and was told “communications has been lost”.
I changed the transfer case switches, no bueno...
checked all grounds, all seemed well. inspected the actuator and wires, no signs of damage.
I then decided to change the Transfer Case Control Module (Dorman 599-192) and BOOOMM... more BS, however the lights on the switch did come on...briefly. now my backup camera doesnt work and I have a “Service Suspension” message.
I’ll greatly appreciate any suggestion you may have. Thanks
mtl111
Arkansas
Not sure what O'Reilly's scanner is capable of but I doubt it has the abilities to access any of the modules on your Tahoe. It will "i assume" only access the main computer.
I would either take it to the dealership and let them scan it or to a shop that has a high end scanner. I wouldn't keep throwing parts at it hoping something fix's it. I myself had to suck it up and shell out about $1500 for a scanner that is bidirectional and can access all the modules newer vehicles have. I doubt you want to buy your own but take it somewhere and see what's up.
Good luck and please let us know what they come up with.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Picknz
Picknz
Yeah, you’re right! Thanks a lot for the quick response.
mtl111
Arkansas
No problem man
veteran111
