2013 Yukon XL RSE Screens Not Working
wjburken
Eastern Iowa
2 weeks ago we bought a used 2013 Yukon Xl Denali with the 2nd and 3rd row screens. Upgraded from a 2008. When we tried to play a DVD for the kids this weekend, it played on the Nav screen, but rear screens were black. Tried using remote (fresh batteries) to turn on, but it didn’t work. Tried using the controls on the back of center console, but no luck. It’s like there is no power to the screens.
I checked the fuses for RSE and INFO and they check out fine. The buttons in the center console light up so they have power.
I pulled the radio to see if there was a loose connection and I noticed the radio had a refurbished sticker. (I think I uploaded a picture correctly.) Is there a chance someone replaced the radio and didn’t get it programmed properly? Would that cause the screens to not power up?
Anything else I should check?
St. Louis
Make sure the screens are set to dvd and not aux. It should be an option in the menu on the head unit.
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
wjburken
wjburken
Eastern Iowa
Thanks for the suggestion.
It is definitely set to DVD as the movie plays on the navigation screen on the head unit while in park, and we hear the audio coming through the speakers.
The two rear screens are showing no signs of life and the remote control or rear console control buttons do not have any effect.
wjburken
wjburken
Eastern Iowa
I guess I’m trying figure out if I need to just take it in to the Dealer and see if they can reprogram the head unit, if the refurbished one is even the correct one, or if I need to start chasing wires looking for a short or loose connection.
In looking at the manual for the system, it is showing some buttons for Display 1 & Display 2 which are not showing on my screen.
60148626-CEE6-49D4-907E-2323E58C853B.jpeg 5F1C0B65-9B02-4DCD-B294-6E99B9AD46B7.jpeg 0CA9E8FB-240E-4CD9-8A8E-B59246371A0F.jpeg F3DC9E26-35FE-4637-B8CF-608D9C591239.jpeg
St. Louis
Interesting. So you can't get to that screen that is shown in the manual?
2001 Yukon SLT
wjburken
wjburken
Eastern Iowa
Nope.
So I don’t know if I don’t see them on my radio because I don’t have power to my screens or I don’t have power to my screens because the radio isn’t programmed properly.
It could also very well be a PICNIC issue (Problem In Chair, Not In Computer).
Not afraid to start chasing wires but thought I’d throw this out to the folks here before I start tearing my interior apart and crawl around with a multimeter.
I would rather risk asking a stupid question verses risking making an stupid mistake.
St. Louis
I believe the harness for the rear screens is located under the center console cup holder area (easily removed). Now I'm not positive, so hopefully someone who knows will chime in here
2001 Yukon SLT
are the rear IR emitters lighting up? you should be able to see them glowing faintly red thru the smoked lens in front of the rear screens when it is set to DVD
St. Louis
When you had the head unit pulled out, did you notice any plugs behind it not plugged in?
What fuses did you check, just ones in fuse panel on drivers side dash or also in engine bay?
The RSE may get it's power from the Center Instrument Panel Fuse Block (Upfitter Block) if it was an add-on/dealer installed option. It's located under dash just to the left of brake pedal. This gets power from locations 37 and 52 of the engine bay fuse panel. Check those too.
It could very well be that the radio isn't programmed for ths RSE option. When doing internet search I've seen this is a possibility.
2001 Yukon SLT
wjburken
wjburken
Eastern Iowa
I did not see any loose or unplugged connections when I had the radio out.
I have checked the following fuses:
Left end of dash:
#19-5A-RSE
#22-10A-INFO
Under Hood:
#42-15A-Radio
I have not checked the upfitter block but will do so tonight.
Does the rear a/v control panel light up? does it scroll thru the options? radio, a/v, dvd, etc..
wjburken
wjburken
Eastern Iowa
The buttons light up for both HVAC and A/V controls but I get no response when I press the A/V buttons. The HVAC controls are functioning properly.
weird, kind of sounds like (maybe) someone opted for a cheaper refurb radio and didn't need the rear screens, it's going to take more troubleshooting either by the dealer or it may be cheaper to go by a local stereo shop and see if they can make it fire up with a aftermarket unit and adapter, wouldn't hurt to ask anyway.
wjburken
wjburken
Eastern Iowa
Have an update on my Radio/RSE issue.
I contacted the dealer I purchased the vehicle from on July 2nd and told them about my issues and even though I didn’t buy the extended warranty and the vehicle was sold AS-IS, they agreed to work with me. Turns out they had installed the refurbished radio prior to me purchasing the vehicle. They couldn’t figure out what was wrong even with the help of GM tech support so GM’s recommendation was that it needed a new radio. Since they installed it, the dealer got it covered under warranty. The dealership has been very stand-up with me on this purchase.
wjburken
wjburken
Eastern Iowa
Have another update on this issue. The new radio did not fix the issue so back to GM tech support they went. GM is now recommending that they replace both screens. The Service Manager told me that the sales group agreed to cover the cost of these new screens, thankfully, even though it was purchased as-is and no service contract. They should have the new screens in tomorrow and hopefully that will be the end of it as it will have a new radio and new screens.
I have been very happy with how the dealer, Billion GMC in Iowa City, IA, is handling this issue so far so a shout out to them.
wjburken
wjburken
Eastern Iowa
One last update. Finally got our 2013 Yukon back today. Replacing the screens did not fix the issue right away but they finally got it all to work. When it was all said and done, I now have a new head unit and two new screens. Took them awhile to get the various components programmed and sync’d up. While it was inconvenient to wait over 2 weeks while they got things sorted out, the dealer took care of everything on their dime and provided a free loaner vehicle.
wjburken
wjburken
Eastern Iowa
Did they say what the problem was
Sorry, Just saw your question.
What happened, as told me by the dealer, was they had replaced the headunit with a refurbished one before I bought the vehicle and the software version on the headunit wasn’t compatible with the two screen system.
Drewphil
