Wheel Hop
ZR WON
All:
I did a search in this section with no results, not to say that I'm searching with the correct keywords...;) Probably a strange question to a lot of you, but I recently purchased a 2015 PPV (LOVE it!). I've been breaking it in the last three weeks or so, finally did a couple 'launches' without traction control on yesterday / last night. Both times the wheel hop was so bad I had to get out of it for fear of breaking something. I've had several Silverados (same basic suspension sans coil vs. leaf rear spring) and never had this issue. Understand I'm not wanting to put slicks on this thing and take it to the track, but honestly, I'm kinda surprised GM wouldn't have identified this issue given the intended application of a PPV (hard acceleration to catch speeders). Outside of those Gawd Awful traction bars I see hanging down on the big power diesel pickups, are there any options out there to help?
Brian A.
2015 PPV
Silver Ice Metallic
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
None of my trucks i do that are lowered have axle hop. Then again i do 3 inches at least in rear. My escalade is over 650 horsepower and im at a 6 inch drop. NO axle hop just nice posi for 300 feet
gat0r
DFW
i dont have this issue either... stock or w/ rear lower level.
you dont have that many miles on yur PPV. was it ragged out?
a silverado will have this issue, due to leaf springs. i dont see how tahoe/burb will w/ coil springs
what is your tire pressure? are tires good? are tires worn?
tires balanced proper? no vibrations while just driving? or on highway?
maybe there is some tire separation or something.
how are shocks & bushings?
ZR WON
ZR WON
Jay:
It has 19K miles and not beaten on at all. Tire pressure is upper 30s, 8/32s tread, no vibration up to fuel cutoff (139). Shocks and bushings are of course fine with the mileage.
Brian A.
2015 PPV
Silver Ice Metallic
gat0r
DFW
huh, sounds good for tire pressure & such
how hard were you launching? what rpm?
if i launch much over 2k w/ TC off, i just boil my tires. i have 22's
gat0r
DFW
you mentioned TC was off... what about StabiliTrak?
BG1988
wheel hop is a Torque issue rather then a Horsepower thing
mine has done that three times, today ( lightly )and several weeks back
I would check the tyre pressure for an underinflated tyre .. should be at lest 36 for balanced performance , 40psi (for optimal MPG it;s about a 7% gain over 32PSI)..
those 80HP motors can lay down the tires on the pavement.(you can see twist cracks in the tyers around the center of the sidewall)
nearly had the front tyres off the ground..when launching it one time
it was Low Speed acceleration and the other time "normal" driving... the whole rear end jumped off the ground..
but 0-25mph 2.3 seconds is not too bad for a 80HP that is with a land yacht that weights 5900 pounds...(with stuff)
I have not had an issues with torque steer.
apparently there is a buffer overflow in the ECM that allows this if you manipulate the voltage (lower voltage or unstable voltage ) it buffer overflows the ECM and Hybrid Powertrain Control Module
and you can do naughty things with it... like burn outs,launching etc..
GM totally under rated that electrical motor.. i'm pretty sure that 80HP motor can get the SUV to 0-60 in 5.5-6.1 seconds
Electric power launch
gat0r
DFW
nice necropost.
i have found 36-40 psi when tires are hot to be too high & a great way to wear out center of tread.
csan2879
