Hello!
5 years ago on “White Steamboat” there were thresholds - steps made of stainless pipes from "Manik".
Stylish but not practical!
I will make aluminum and stainless steel. The mounting brackets to the frame are made of stainless steel and titanium.
The first version used an aluminum channel from a sheet of 6 mm. At first, the brackets were made of carbon steel.
Channel ends rounded by welding in argon
The powder coating of the channel - hung it on the brackets - put a sheet of corrugated aluminum on top.
On the front surface scrolled recesses in the style of rims KMC HD.
P.S. Continued perversions with thresholds should be .....
They will be slightly adjustable in accordance with the size of the body lift. And quick-detachable.
