03 Yukon slt awd with 4 low
Ou812
PENNSYLVANIA
New member here,. Anyone have a Yukon XL in slt trim that is awd with a four low or am I crazy. And it is not a denali. Lol
Big Mama
Virginia
Does sound like an albatross for sure. I’ve seen auto with low of course but haven’t seen any Tahoe’s or Yukons other than Denali that were AWD but there are lots of combos out there. What year?
Ou812
Ou812
PENNSYLVANIA
It's a 03. Where the push button for 2wd should be there is a button to turn off traction control. Then underneath that button there is neutral and then four low like a normal setup.
Welcome to the Forum from NH.
I have not seen or heard of that setup, but most folks here are more knowledgeable and more experienced than me on these trucks.
GMT800 2005 Tahoe Z71
Navy Supporting Member
2002 Tahoe. Mine is Auto 4 WD on the top button. Then 2 WD, then neutral, then 4 HI button and then 4 LO button. Is that what you have? Welcome to the forum from Oregon.
Larryjb
My '02 Tahoe has the following selectable options:
Auto 4wd
2 Hi
4 Hi
4 Lo
It's a nice feature. In slippery conditions I use the Auto 4wd. 4Hi may cause binding of the drivetrain on turns. I use 4 Hi in snow as it is more effective than auto 4wd.
For normal driving I use 2 Hi.
Ou812
Ou812
PENNSYLVANIA
I have not seen or heard of hat setup, but most folks here are more knowledgeable and more experienced than me on these trucks.
Auto 4wd
2 Hi
4 Hi
4 Lo
No sir. Top button traction control. Middle button transfer case neutral. Bottom button 4 low
While I did run shops many moons ago I am still learning that the Yukons and Tahoes have so many differences in their options and I am still getting used to that.
Ou812
Ou812
PENNSYLVANIA
Well, it would be the AWD type without the central disconnect. The difference between a 4x4 and AWD front differential is in the right side axle tube and shaft. The center sections are the same.
If I was to order axle seals I wound need to go off of the rpo code?
Bwaldron
