My 2013 Denali recently dropped mileage a decent amount and developed a slightly rough idle. Have run 2 tanks of fuel injector cleaner, check for leaking injector (no pressure loss on sitting off for 10 minutes), and no misfire codes. Checking fuel pressure found static and startup 60 psi, then a few minutes later it drops to 43 psi at idle, which is the exact same time the idle begins to become slightly rougher. You can tell when the fuel pressure drops by the change in idle quality.
My older 09 Yukon operated at 59 psi steady all the time. Both vehicles have the FSCM instead of regulator so not sure if that is the problem or not. No codes, and LT and ST values in range of +3 to +5%.
Any ideas of normal operating pressure?
