Uh, what is this?
mijohnst
I pulled up my carpet and saw this with water all around it. Is this the sunroof drain line?
3Dog
Rocky Mountain high...
It's not a drain. It runs underneath along the frame rail, and snakes under the fuel tank (past the transmission). I haven't traced it to its terminal point. I'd be curious as well. @Tonyrodz if that is the shifter cable, I would expect it to run to the transmission rather than past it?
That does make sense. Pretty sure its the shifter cable. He could always keep his foot on the brake and put it in gear-- back to neutral then back into gear. Of course the vehicle will have to be off--and see if he hears or feels clicking coming from it. If he does then it's the shifter cable.
wjburken
Eastern Iowa
What does it attach to under the dash?
Do as Tony suggested and cycle the gear selector. If you get nothing, maybe engage and disengage the E-brake.
Drewphil
