03 Tahoe window won’t roll down
Redfire Metallic
My window just recently began to do this. Please if anybody could give advice to what it potentially could be the problem it would be very appreciated. Vid link is above... Thank you! :)
wjburken
Eastern Iowa
You need to take your interior door panel off and look at the regulator and also make sure the window is still in its track.
I had the same issue with my passenger front. Doing exact same thing. Turned out to be the window regulator steel cable was frayed. It was binding in the plastic guide, preventing it from going down. Take the panel off and check those metal cables.
CKendrick
