Body molding/trim for roof
I've seen a thread(s) either here or on other forum(s) where someone used adhesive-backed body molding that somewhat matched the embossed rails in the roof to cover the holes left from removing the roof rack. Of course, I can't find anything now- no threads, no Google pics, nothing.
Has anyone done this or can suggest a supplier for such molding? I'd rather some pre-made lengths with tapered ends but can probably make a cut-to-fit length from a roll work. Looking for something 1.25"-1.5" wide, 70"-72" long and minimum 5/16" height including the adhesive foam.
Roof ribs:
Side profile:
Ilikemtb999
Denver
Not what you’re looking for exactly, but the hybrid looks like it’s got something bolted over the roof rail holes to me. Like mini roof rails?
Mine has some thick rubber plugs over the holes (I’ve seen some ssv’s like mine and other where they never had rails).
ivin74
05 NBS Nali
Htown, Texas
Roof ribs:
Side profile:
There is a TYF member that did what you are wanting to do to his NBS SUV.
I believe he used a 1" universal black door trim (it came in a 16ft roll with the tape already on and I found it at pep boys for like $15)
https://www.tahoeyukonforum.com/threads/how-to-plugging-roof-rack-delete.1454/
@YNOT
Here is a pic of an NNBS with the trim you are looking for.
I didn't know that about the Hybrid. I'll research this cuz I'm a fan of OEM solutions. Thanks for the help!
I got some plastic tree rivets and painted the heads, but the nutsert sticks up way higher above the roof than I thought so they won't be as low-profile and clean as I want.
@YNOT
I ran across that thread but he hasn't logged in for over 8 years and never posted any links to what he used. I have been Googling for rolls of trim, but I'm not finding anything that looks promising. Having finished ends or finding a style that's solid so I can finish (cut/sand, etc.) the ends is the problem.
YES!!! Where did you find that pic?!
wjburken
Eastern Iowa
What about something like this?
https://www.brandsport.com/trmg-pc02-01.html
Or
https://www.brandsport.com/trmg-cm44-01.html
Great minds think alike. ;)
I found some of that last night right before I fell asleep. Actually, I was on Trim-Gard's site. They have a lot of options and even a few of the colors in their chart look really close. They're in Canada so shipping would probably be the deal-breaker, but Brandsport is in the States so that may very well be a saving grace. They even have one style that's really flat and 3.125" wide, so I could cover the footprints as well. It's twice the price, but that may be worth it if I won't have to spend hours buffing the finish. Thanks for the help!
Think of it like this, custom work is not cheap.
Ugh. Painfully true! Gotta pay to play and "pay" isn't limited to just money. Labor, tears and often blood are expenditures as well. Especially for someone like me that has to put more work into a mod than money.
...and what you are trying to do is one of a kind.
Yeah, I'm often putting my own spin on even the common mods cuz I always find ways that might can be improved (Recent example: My ALC compressor-to-Airlift bag venture). Most of the time, if I post a thread seeking help, the subject is usually uncharted territory and I get few replies. I'm not complaining cuz I understand that I'M the problem!
Honestly, I was expecting this thread to get crickets as well. I'm pleasantly surprised in and appreciative of the turnout!
My options as of now are:
A) Buff out the footprints and get a narrower strip of the molding to cover the holes
or
B) Check the scrap yard for a NNBS and experiment with drilling off the nutsert flanges and, if it's a viable option, do so on mine and use the tree rivets I made after buffing out the footprints
If the footprints won't clean up to my satisfaction, I'll just cover them and the holes with the wider strip of molding strip.
... Or maybe I'll just get the wider strip in the first place and be done with it. So this leads me to ponder if I want a raised rib to match the existing ones or aim for discreet as possible.
*sigh*
These "IF-THEN" flowcharts in my mind seem perpetual and the only end is for me to get fed up and "throw a dart" or for it to be decided by an extrinsic circumstance.
Ilikemtb999
Denver
Looking at mine, the rivets seem much smaller (though I haven’t peeled back the covers).
KMeloney
I wonder if the OP saw my post from years ago when I did this on my black truck. It's been a while since I did this, but I think I just did a search for adhesive backed door molding. I found molding that tapered at the end(s), but as I recall I couldn't order the exact length. So, I ordered enough, with 4 tapered ends, and then I had to splice together the pieces to get the proper length and have the ends taper.
Also, I recall that it was a bit of a PITA, 'cause I had to dremel out "pockets" from the underside of the molding for the outserts to stick up into (or else the molding wouldn't lay flat, as you can imagine). This wasn't as easy as I thought because you had to dremel through the double-sided tape backing at first (which got a bit messy). With the right tools and more patience, it's NOT a tough job, really.
I'll try to locate some pics of when I had this on my truck...
I did read one where someone had to clearance the backside for the nutserts, as I figured I'd be doing. But the thread was older and the pics didn't work any more. It very well may have been yours. Tedious projects that require precision to result in visually perfect appearance are kinda my thing.
I'm not sure what I'd rather do- get a long roll of molding and cut it to length and finish the ends or get shorter molding with pre-finished ends and mold the splices together. I guess it depends on the number of splices. I'm thinking the former would be better.
St. Louis
Are the Esky/Denali side rails lower profile, or are you just not wanting anything taller than the roof ribs that are there?
SRQYukon
Sarasota, FL
Here's mine with the universal 1.5" self-adhesive molding. Easy to trim the ends with a tapered end. Came from Dawn Enterprises on Amazon, but I see they no longer carry it. I also had to Dremel the back side, but it wasn't too bad. Sorry I don't have a better photo but my Yukon is in Florida and I'm in SC.IMG_5321.JPG
The Esky/Denali rails certainly look better. But they're still very protrusive and I'm aiming for as clean-shaven as possible. If welding up the holes and painting the roof was an option at the moment, this thread wouldn't exist.
Here's mine with the universal 1.5" self-adhesive molding. Easy to trim the ends with a tapered end. Came from Dawn Enterprises on Amazon, but I see they no longer carry it. I also had to Dremel the back side, but it wasn't too bad. Sorry I don't have a better photo but my Yukon is in Florida and I'm in SC.View attachment 236998
I'd be quite happy with that. I found Dawn Enterprises' site and they have a find-a-retailer link. Thanks for the info!
KMeloney
Yep, I think you saw my post...
Unlike SRQ, I used a narrower molding. I think there are trade-offs between the various widths. The narrower molding will maybe be less visually obtrusive, but it also is more flexible side-to-side, and so aligning it perfectly straight might just take some more attention than something much wider.
Whatever you go with, it'll like be one of those things that only you really notice -- but it does completely clean up the roof lines and make the truck look great.
varminpoolteam
