Stabiltrack/ABS
07hoeCHEVY
Hey just changed my rear struts an the stabibtrack light an abs came on what is that about ???
Sent from my SM-N950U using Tapatalk
Double check that you didn’t pop an ABS sensor plug loose. Common thing when your messing with the upper bolts.
Truth.
*Struts are in the front, shocks are in rear
The plug connector is on top of the frame and your socket goes right over or on it. Did you replace them with Autoride shocks?
*Edit*
Site or computer froze up while replying. Glad you got it!
07hoeCHEVY
Truth.
*Edit*
Ok I got them backwards will be doin struts tomorrow (front) [emoji851]
07hoeCHEVY
Truth.
*Edit*
No auto ride ..
Saved the "best" for last, huh?! Good luck! If you're doing this at home and using strut compressors, I had to use two sets of them. With one pair, they were bending and looking really sketchy before I had much tension off the top plate.
No auto ride ..
Cool. I've seen people swap in regular struts both intentionally and by mistake.
07hoeCHEVY
Got the one piece set from a1 auto
giroux68
Just had the same problem. You all rock here. And how is it a socket and undo that connector so easily, but the oil pressure plug needs a superhero to get undone?
DarkHearse
