battledenali
New Jersey
Installed a pair of Custom fab Rigid D2 lights in the fog space. And a 30” bar behind the grill to activate with the high beams. And then modified them so you can run the fogs and high beams at the same time.
View attachment 235378 B57D4EA6-69FE-45EB-82FF-F4B6DBE46F53.jpeg3366E686-6614-4CE0-AC26-F72BC03EA47B.jpeg
humer101
NJ,USA
View attachment 235378 View attachment 235377View attachment 235379
I really don't like the lights inside the grill, but you make me think about it.
Can you send me the information to start to look at.
Thanks [emoji111]
Sent from my Pixel 2 XL using Tapatalk
BlackYukon
I'm kind of a Retard
I Replaced all of the incandescent lighting on the vehicle with Diod Dynamic LED's except for the fog's, I went with Lasfit LED's for those.
This is one of the best mod's iv made to the vehicle so far, it made me realize how absolutely crap the stock headlights are that come with these vehicles.
Hattie2879
Replaced the stock tires with Goodyear Wrangler DuraTrac, kept the original size (265/65/R18). I like the look and so far they feel good driving down the road, not very noisy either. :waytogo:
battledenali
New Jersey
Thanks [emoji111]
I had a local shop do the fabrication of the light bar and fog light brackets. So I don’t have much to share because the parts were custom made for the Denali. For some reason there is very little for the Denali off the shelf.
SARNCAN
That looks great!!! How did you apply it? Did you remove the emblem?
I was planning to remove the emblem and do the job, but I figured out that it needs to be removed from inside (got some clips that locks it in place).
Option 2 is what I‘ve done, by using large plastic roll to cover surrounding area that may get spray dust by accident. Then I cut a square working area around the emblem and use a tape to hold the plastic in place. I believe I’ve used three layers/coats of the Plasti Dib.
kiwi
Mother Яussia
Did my second scheduled maintenance.
Oil change, new cabin filter (15k km and it was very dirty, decided to change it myself every 5-7k km), some winter preparations - cleaning/oiling power steps, rear ammo cleaning, greasing for locks and all rubber seals.
Dealer did not find the 4wd service reason again :( said they do not see any errors at all..
kiwi
Mother Яussia
My ride showed 4wd service notification and tried to switch to 4wd lo while i was driving in 2wd mode. OFC i didn't even touch the knob.
As for the transmission fluid change, campaign is not active here yet.
Besides i don't think its fluid issue, i assume my TCM module is buggy.
BlackYukon
Wrapped the new esky mirrors since I didnt do blinkers...
Sent from my SM-G975U using Tapatalk
Did you disassemble the mirrors to wrap the blinkers? I got my Esky mirrors in yesterday and want to wrap the blinkers before I install them.
K2 Kaiju
The Depths
Nope. I have a 4" roll left over from doing the the door trim. Cut it in half and just a little longer than the length (including around inside where mirror is). Peel, stick, and trim with razor. I got a cheap install kit off amz for like $10 when I did the doors. A heat gun is useful for setting the wrap in curves. Im new to the wrapping bit, but its pretty straight forward and simple; if you mess up, just peel it off and grab another piece...
Sent from my SM-T580 using Tapatalk
Hodmjstone
