Installed Alpharex NOVA headlights
mackmcmillan
That. Is. Awesome! Truck looks like a better version of the Tango and Cash hero truck! I say it not to knock the movie ride, but the actual vehicle is such a haphazard build up close!
The Raven
Fleetwood, PA
@TheRaven posted some pics with the push bar, hope it helps
Thanks but your bar is very different from mine. Your upper bar is quite a bit higher. Mine sits centerline with the top edge of the headlight enclosures. So where the alpharex lights bulge out at the top is dead center on the upper bar, and i've got about 1.5" of clearance with stock lights. So best I can tell, it would be like a ballhair's clearance there.
sanco
sanco
Chicago
Aw man sorry to hear that bro, I was hoping different angle pics with the measures would change the outcome for ya
Wheel and tire specs?Looks super.
Thank you, 18" fuel vector wheels +1mm offset with good year 275/65/18 duratrac all terrain tires
BG1988
has this bubble effected MPG? I have 420$ saved up so far
arsene2000
Got them in! Can't wait to drive it at night.
Are these flat black or jet black ? can't decide between them...
arsene2000
what i meant is: are DRLs working rght off the bat, or did you have to wire extra DRL harness plugged to switched power ?
sanco
sanco
Chicago
they are completely plug and play, no wiring is required. The only thing you would need to wire up is the DRL harness if you want them brighter all the time. otherwise the DRLs run all the time and adjust with the headlights.
arsene2000
mine are not.
i installed the nova lights but my drl only show when low/high beams are on
sanco
sanco
Chicago
mine are not.
Really? They're not super bright but they are on. Stupid question but are you looking at them when the car is in drive? I know that if the car is on but in park the drls are off only in drive during the day they turn on
08z71bgm
Long Island, NY
How’s long term use with them? I see you’ve had them for a while now.
Dh1280
