2007 Yukon Denali Build (This got outta hand really quick...)
esoteric_ast
Sorry, I've been terrible about updating this thread... I just looked and it doesn't seem like I took any pictures during this last fuel upgrade. There really isn't much to upgrading the pump. Use the factory bucket and gut the thing, saw off or grind down anything on the inside of the bucket to make as much room for the pumps and fuel volume possible. Drill a hold in the top of the bucket with a step drill for an AN bulkhead, use a 90 degree fitting (or two) off the top and a Y fitting if using dual pumps. Wiring is plug and play with a Racetronix hot wire kit (you can also make your own). They make a kit for single and dual pumps that works great. Run -8AN if you plan to use E85 or are making big power. It's a pretty simple install, if your truck is newer you might have a FPCM that controls the OEM pump voltage, you might need to reprogram it if you plan to keep it.
**I forgot to add that with dual pumps, you should drill some 1/4" holes about halfway up on the front of the bucket to avoid sucking the bucket dry when under 1/2 tank of gas. Also, dump the return using the factory supply directly into the bucket. Make sure you use submersible fuel rated hose in the tank and just zip tie the pumps together. With two pumps and the socks on the bottom, there is really no movement or anywhere for the pumps to go.
Thanks! I will be taking my 2014 Tahoe to the dealer and have them fix the clogged canister/vent so while the tank is down I wanted to upgrade the pump for upcoming blower. I have the 5.3 LMG flex fuel engine.
67RS427
67RS427
You may not even need to upgrade depending on what power you'll be making... I put my blower on the stock 6.2L and ran my factory fuel system for awhile. It made 600+ hp on the stock fuel pump and my wasn't a flex fuel pump. Your pump might be just fine unless you plan on a cam and other mods. Just a thought.
esoteric_ast
Just cam and DOD delete. Shooting for 500 to the wheels.
Chert_Detective
How's the truck man? I'm about to button up the performance side of my build in the next few days and reading up on everyone's suspension. Have you made any changes since your last post, still running the QA1 stuff?
67RS427
67RS427
Truck is running great... I went through the entire motor while I was rebuilding the transmission. Broke an input shaft right before New Years. Rebuilt the transfer case since it was original. Still running the QA1 double adjustables front and rear. The front springs settled a bit and it's sitting really low. Need to raise it up but I'm getting lighter 20" wheels and drag radials that will be a few inches shorter. Ride's great though, can't wait to get it to the track this spring. Hoping to get in a 10 second quarter mile soon.
Onebad1983
Resident Country Dumbass
I'm too lazy to run back through this whole thread again, what all is done to it again?
Please keep us updated.
Dantheman1540
Sugar Loaf Mountain
If that wasn't enough, I also installed a Mishimoto Radiator (for those wondering it performs way better than the stock one). I got some great pricing by calling direct. I also installed 7 & 9 blade fans from a 2500HD truck.
In addition to all that, I upgraded to a Granatelli 103mm Throttle Body... Too many issues with my Nick Willams and the throttle blade snapping shut from the blower
Front suspension:
Very nice build!
How has that throttle body been working? I've been running an LS2 90mm on my Magnusson for a few years without issues but I'm scared to upgrade to a Nick Williams.
Also what do you IATs look like with the chiller? I typically see 10-15* above ambient normal driving and have seen close to 140* after a 1-2-3 gear run.
Lastly why are you sticking with the MAF? I switched to speed density when I first put my blower on and have had no issues with it.
67RS427
67RS427
Too much to list really, you should browse through the thread...
A short version of my project: 2007 Yukon Denali, Built/Forged 402" Iron Block, Lunati crank/rods, Wiseco Pistons, BTR Stage 3 PDS Cam, Brodix 6 Bolt CNC Heads, Fully ported LSA Blower, ZL1 Lid reinforced, 2.5" Upper/10% 9.1" ATI Lower (14.5-15psi), Kooks 1 7/8" Headers, Gutted Kooks Y Pipe, 1000cc FIC Injectors (I have ID1300x2 injectors going on in the next week or two), running pump E85, Mishimoto Radiator, HD2500 truck fans, Custom Blower Chiller, QA1 Double Adjustable Coil Overs front and QA1 Double Adjustable shocks in the rear, Front Drop Spindles, Rear 4-6" Drop springs with bags. Transfer case was original and just rebuilt a few weeks ago along with another fresh transmission build (broke an input shaft). Running a Circle D 3k Stall Triple Disc convertor. Self tuned with HP Tuners. Front diff is rebuilt to OEM spec, rear 10 bolt Diff has a TruTrac. Best ET was an 11.77 @ 124mph and that was in November here in Michigan on SNOW TIRES spinning all 4. Planning on stepping down to a 20" light weight wheel and running drag radials on all 4. I have 16" Wilwood brakes waiting to go on sometime this month. Full 5" intake and MAF only tune right now.
Honestly, probably forgetting a lot... Probably making just over 1,000hp but I will get it on the dyno for a solid number.
Very nice build!
My IAT cruising around has gone up slightly since I removed my heat exchanger fans. I'm also running a very thick exchanger that doesn't allow a lot of air flow at low speeds. Without the chiller, I see 30* above ambient right now. Usually only 15* when it's warmer out. With the A/C Chiller turned on, I see temps right at ambient or 15-20* below typically. Temps don't go above 115* after a 1/4 mile run and quickly recover to 15-20* below. Before my chiller, I would see 160-200 degrees on a long hard freeway pull. No longer an issue and the chiller will be working better when I get my A/C problems worked out (currently have a blockage or bad compressor).
I'm running MAF only because it works really well for me. I don't have any drivability issues and I don't need to make big changes when the temp changes or for altitude. I have considered getting my speed density dialed in so I can run a blend but I do not plan on getting rid of my MAF, no reason.
I use a Granatelli 103mm TB now and LOVE it... No issues like I had with my NW 102mm unit. You will notice more power/performance if you upgrade, ANY restriction before the TB is lost power on these blowers. Get the biggest intake you can fit and get a Granatelli 103mm on there. They are cheaper than the NW units.
Dantheman1540
Sugar Loaf Mountain
That's awesome to hear about the Granatelli! And the interchiller sounds really badass! Not sure I'm ready to go that far since I don't race but that's the first I've seen done like that seriously nice job 30* below ambient is incredible without an ice box. Especially with an LSA which I've seen tend to get a little hotter than other TVS rotor setups. :waytogo:
If MAF works for you I'd stick with it too.
Seriously sweet build I will be watching!
67RS427
67RS427
I do have an Ice Box that acts as a reservoir for chilled fluid during a long pull. I don't actually fill it with ice. Thank you, it's been a ton of work to get it to this point but it's been worth every hour and dollar. I don't have a ton of money into this build and you couldn't buy a car or truck like this. It's become so much more than I anticipated and will be even more happy when I click off that 10 second pass here soon. This is still a full weight truck with a spare tire and my kids car seats in the back lol... It's gonna make a world of difference when I cut 15-20 lbs of rotating mass at each corner. Can't wait!
Dantheman1540
Sugar Loaf Mountain
I've got a 2 gallon Icebox too but have only iced it one time for fun. A 10 would be absolutely nuts in such a big truck. I think my RCSB probably runs high 12s or low 11s if I put it on a real tire and its scary to drive lol.
67RS427
67RS427
I thought I posted a video of my last track run but I guess not...
67RS427
67RS427
I bet the guy in the Vette was surprised... lol
Friggin badass! You beat the vette too? I hope so :D
More shocked then surprised lol.
I most certainly beat the Corvette and it was on drag radials, definitely not stock either. A few guys came up to me after that race and said, “holy crap, is that thing on snow tires?” lol... sure was and the next day we got 8” of snow. Guess who had to park the race car and guess who was out playing in the snow lmao
Sam Harris
[emoji23][emoji1787] awesome
Towmaster
