Seat swap from Yukon xl to Tahoe ?
Toddzaracki
I have a 2008 Chevy Tahoe with rear bench seat . I found a 2007 Yukon xl being parted out with bucket seats . Will the bucket seats from the Yukon xl fit in my Tahoe and plug in ? It originally had bucket seats but someone swapped them out.
Multnomah Falls
Military
I recently asked a question about my 2002 Tahoe with the front seats having the seat belt attach thru a hole in the seat bottom that comes apart over time. The 2003 models switched to the belt coming out of the plastic covered spot on the outside of the side of the seat. I wanted to swap out the seats. for the 2003 models. I think the answer to your question is the same as I got about my question. If your Tahoe had the bucket seats before and then was swapped to the bench seat, then the buckets out of the Yukon should bolt in but the wire plug ins may not be an exact match and then have to adapt as needed.
Is he talking about replacing the front seats or the bench seat behind with buckets instead? I may have read this wrong.
misread that, I think the rear seats are mounted different on the long wheel base -vs- short wheel base.
wjburken
Eastern Iowa
2nd row seats from long wheel base NNBS will not fit in short wheel base NNBS, or the other way around, regardless of being bench or bucket.
Dustpan
