Fosscore
If you have pellets clear up to the purge valve, your canister is shot and has been distributing charcoal throughout the vent system. You’ll need to disconnect everything and blow out the lines, and replace the canister at the least. I’d go ahead and replace the vent valve since it’s probably shot anyway.
What I was afraid you were going to say given the videos I watched.
Well at least all 3 parts of that system will be new.
The best way to blow out the lines once I remove the canister and vent valve underneath?
I would think just a compressor and blower nozzle, I haven’t had to do that but the lines aren’t big so anything you can get to help kind of seal up the end where you put the nozzle into. I would blow from the engine compartment back to the disconnected end at the fuel tank, and then blow the other lines by the tank out after removing everything.
Fosscore
Sounds like a plan. Thx man. Plan to remove the canister and solenoid tomorrow (bit tight under there, blow out the lines and install once the parts arrive. Of course the purge valve is the easiest on the manifold. :rolleyes:
Checked all local stores on availability, pricing and confirmed with RockAuto on parts numbers. No local shops can compare to Amazon pricing on this order, plus 1 day Prime shipping, plus a gift card balance as well. Winning! Parts should arrive tomorrow.
ACDelco 215-464 GM Original Equipment Vapor Canister
$86.01
https://www.amazon.com/gp/product/B000EQVSME/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
ACDelco 214-2149 Professional Vapor Canister Vent Solenoid
$14.07
https://www.amazon.com/gp/product/B001KSCSQU/ref=ox_sc_act_title_2?smid=ATVPDKIKX0DER&psc=1
And already received and installed this part to complete the hat trick.
ACDelco 214-1105 GM Original Equipment Vapor Canister Purge Valve
$19.20
https://www.amazon.com/gp/product/B000IXUBIA/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
$86.01
$14.07
$19.20
you might want to drop the spare for a little more room, shouldn't take you more than 45-1hr to do even if you haven't done it before.
pro tip: if you unbolt and unclip the gas filler tube from the rear quarter panel and then pull it down from underneath it makes getting the solenoid filter tube on & off super easy (it clips onto and zip ties to the filler tube inside the quarter panel), after you are done just push the filler tube back up and bolt it and clip it back on.
***and the little plastic tube connectors are push clips, push the clip to release the tube
it looks like you ordered the "standard brand" solenoid I put one on the front and then one on the rear, front failed about 30 days later and the rear failed about 2-3 months later, evap canister seems to be holding up though. just my experience with them
Sam Harris
Ok, so I got the American Racing Longtubes installed last week. I had some issues directly afterward, as the spark plugs were not all fully seated, and had to figure out what the noise was and get it addressed. After installing the headers, the spark plugs are really difficult to access, and they feel tight when they are not, since the socket tends to hangup on the outside edges. Needless to say, it’s taken me a bit to get some before/ after videos. I now have the headers (with cats), and an 18” magnaflow muffler (sorry, don’t know model -think it’s: 12259) Really digging the Accel Ceramic wires (9070C). They’re the perfect length, and stay out of the way of the headers.
Here are some clips. Not the best quality, and you really need to play on a system with a subwoofer, so you can hear the lower tones.
Before headers 30-70:
After headers 30-70:
Warm start:
Stock:
Headers installed:
Headers + Magnaflow:
And a few (albeit ******, but obligatory) photos:
Next up on my list is a Black Bear tune!
Warm start:
Stock:
Headers installed:
To access the plugs with headers, it’s pretty much necessary to pull the front wheels and fender liners and go in from underneath. If you use a standard 5/8” plug socket it should clear fine.
Warm start:
Stock:
Headers installed:
And your 4wd still works! Nice.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Leveled my 05 (Keys and z71 springs. No spacers in the rear)
275/70r18 BFG KO2s
2016 18" take-off wheels
Next is going to be doing something with the running boards. I like having them, but the factory plastic ones are faded and look terrible.
Beautiful! :)
HiHoeSilver
Away!
Chicago
They're cheap MOTO FAB keys off amazon (1"-2.5" I believe). The bolts on the keys are in roughly the same as they were from the factory. I didn't count turns. Its a little stiffer but that's with the bars cranked and MUCH stiffer tires. Overall I'm still happy with the ride. Haven't done shocks because the truck has AC Delco shocks that probably have less than 10k miles on them. If I have any issues I'll probably go to 5100s.
For the rear I used Moog 81069 springs. No additional spacers or anything. Might add some airlift bags. Depends on how much it sags when I hook my boat to it.
Fender heights are 38.75 front and 39.25 rear. I'm expecting the rear to settle some and I didn't want to crank the keys any more.
I have not trimmed anything and it does not rub even at full lock forward or reverse.
The pictures really don't do it justice. I am thrilled with how it came out.
Thanks for amazing info.
Bombsquad85
Northern VA
Warm start:
Stock:
Headers installed:
Do you have a link to these headers?
Buford bubba
