Sam Harris
I'd go with AC Delco o2 sensors. Headers look nice! What's the rest of the exhaust gonna be Sam?
I’m planning on just using stock for now, to see what it sounds like. I think I’d like a dual tip on it, but kinda want to wait and see how she purrs with the headers and high flow cats.
PPV12HOE
NC
Set of towing tires on order for the 2006 Yukon XL 4:10 x4 235-85-16 31.7 height perfect winter tires 10 ply . There even pinned for winter studs. But I won't be using them . Serious Yukon XL in service.[emoji106][emoji41] Yes Im going use steel rims 16 - 6.5 wide.
need caps and lug nuts.
Sent from my LGL84VL using Tapatalk
I run ten ply on my 00 suburban as a daily driver... handles so much nicer... no rear end sway...
PPV12HOE
NC
No. AAA wouldn’t tow it. Luckily my dad has a buddy that lives up in NY who was able to take the boat and the wheels to his house. Engine is still under warranty tho. Changed in late 2016 and it had a 3 year 50k mile warranty so just under both those
I updated my AAA to the RV plus and they have to tow anything including trailers...
Woodblocker55
Im getting last coat clear coat on rims . Tires are going on maybe end this week or the next ..how much tire pressure gave you a good ride when not towing or empty ? I know towing It needs like 60 psi + but did you go with 35 psi on your 10 plus ?
PPV12HOE
NC
I run 50 psi in mine front and rear they wear pretty good there and ride great... 60 psi wore the middle out...
Sam Harris
Dropped her off at the exhaust shop this morning.. so I gave the old beater Civic some much needed attention. Washed and waxed. Poor thing has taken a beating.
Sam Harris
Amazing, the headlights look clear. Usually they're yellowed and cloudy.
I had aftermarket heads in for years. So the originals sat in a box in my garage. [emoji106]Unfortunately, the passenger side decided to break open. I’ll let it dry out, and try sealing it back up. Fog in one of the tails too. [emoji53]
Get that fog out then seal around the lens with silicone, and where the bulbs plug in use some dialectic grease. Keep everything nice and dry.
Sam Harris
Yessir! I wish I had known before washing it this morning. Lol.
dizhai
