2015 Yukon Denali headlight
finston
Hi,
This is my first post. I looked but couldn’t find any info on my particular issue. My Denali passenger headlight will not work correctly. It flickers 3 times then stays off. The led running lights are fine. Any ideas?
Thanks
Jason
SARNCAN
CMoore711
Should we assume you’re referring to the low beam?
CMoore711
Well hopefully it’s the bulb and not the ballast. That would be a bigger PITA to replace.
SARNCAN
Usually ballast last long, most likely it is the bulb that needs to be replaced
CMoore711
I do agree, but I notice in mine it seems like the low beam HID’s fire up quite often when the headlight switch is left in Auto. I feel like too much, it’ll still be pretty light out and I’ll notice from the reflection on the back of the vehicle in front of me that my headlights are on.
So it’s become a habit for me to just switch them to parking lights during the day so my low beams aren’t on for no reason in Auto headlight mode. Because I know constant firing up and shutting off when in Auto headlight mode can prematurely wear out HID ballasts and bulbs.
finston
finston
I'm not worried about the ballasts running too long, I only drive about 1k miles a month.
DrSpork
