DDM HIDs installed
04silverL
Pleasant Hill, CA
Just finished up the install on my DDM HIDs. Got the 55W with the relay harness for just the low beams. Was not that bad of an install. Just time consuming. Thanks to Modded for the writeup in the technical section. Really helped out. It is a night and day difference between the stock headlights and the HIDs. Ill try and get some pics tomorrow night.
Simon
puckhead
CO
Nice dude! lets see some pics lol. what temp did you get?
alpineflip
Did you just get 1 relay harness or 2? I put a DDM kit in mine and bought the relay harness but never installed it then I questioned if it would reach both bulbs then back to the battery. I have been running the kit less than a month but eventually should add the relay in I'm assuming, did you just run it from the battery to the passenger side HL and then across to he driver side?
1STIMEYUKON
bakersfield ca
im looking to get a set of hids for my lows and fogs but what is this relay you guys are talking about? is it necessary?
alpineflip
Here is a small description of the relay harness DDM Tuning I am not currently using one, everything powers up but I do have one and wondering whether or not to install it.
Conor
"Bob's your Uncle"
Seattle, WA
Simon
If you get a chance, can you write up a quick run through of the steps you took to install the wire harness? I am in the same boat as the others who posted. I have the harness, just have not taken the time to install it.
BadDaddy2003
