time to upgrade the lights
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
How do you know they are True HID Reflector's? Looks identical to any other clear headlights with the cut-off shield.
From the Ebay Ad:
"1988-1999 Chevy/GMC full size pick up truck / 1992-1999 Chevy/GMC Suburban euro clear head lights by TYC with built in Philips/Osram HID system!
Complete head light assembly with HID kit (left + right + complete HID system)
Philips/Osram HID is very high quality and is used by many well known car maker such as BMW, Audi and etc... as standard factory equipment"
Doesn't say anything about them being a HID Reflector Housing. Just the HID already setup.
Their HID reflector because they use the Same HID components that Ford does on their 06 back navigators. 09 back mustangs. Currently on the town car, lexus used it for a while etc. ITs called D1R R is for reflector and the housing and metel shield is designed differently on the inside. To the naked Eye it looks the same, But the reflector is cut very differently, and the bulb has more components than a d1s or HID "kit".
blkcam
underwater
8K HID's in my TYC Crystal Clear Housings. And Clear Signals. Clear Corners. Which I cant seem to find anymore.
Did the 8K's come with the kit or did you get them separate? If you got them separate did you need to change the ballasts?
haks310
Got LEDs?
SoCal
Ditto what RT said. LoL a reputable company like TYC wouldn't stick HIDs in a regular halogen housing, would be illegal.
Lifted99 doesn't have the TYC HID kit. The TYC HID kit comes with bulbs rated at 4300K. You would be able to swap out the bulbs though, just gotta make sure they are the correct 35w and D1R bulbs. I'm planning on switching the ballast and bulb to 55w 8000K.
blkcam
underwater
haks310
Got LEDs?
SoCal
Yeah I know you can just change out the bulbs but I'm going with a 55w ballast. As you go higher on the Kelvin scale you start losing usable light amount, lumens will decrease. 4300K rate bulbs will give you the highest lumens, usable amount of light than a 6000K or higher bulb would. This is why car companies use 4300K bulbs as OEM. A 55W ballast combined with a 8000K bulb will give me the same amount of lumens, even a bit higher and yet give me the blue hue I want. I would just switch out the bulb and keep the 35W ballast but I'm after looks and performance.
Rollin Thunder
Va Beach Va
d1c= ****** bulb. Its really a d1s bulb with a d1r housing base. IN a projector housing the housing does all the work.
In a reflector housing the reflectors job is to disperse the light the bulb emits. The bulb creates the cutoff , its a 50/50 job, remove one and your pattern goes to crap.
Here is a picture of a D2R bulb (same as a d1r except the ignitor (silver box on the base of the bulb) is separate from the bulb) Notice the bulb has a shield. With out that shield, your beam is going to be shit (which is what the d1c bulb is missing)
blkcam
underwater
I have a feeling Im going to be doing exactly what you are doing because I also want 8000K. Where are you getting the ballasts from? I don't want to get some cheap junk off ebay.
Is this what you currently have? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=400040757050
haks310
Got LEDs?
SoCal
Yeah, same seller also. I was going to get a HID Kit from DDM Tuning, but I am pretty sure the bulbs they use are D1S and not D1R, so I am still looking.
mikeykey
Man this thread gets confusing as hell when you don't know much about lighting. Not trying to thread-hack, but can someone point me to a clear GLASS head light that's not $250. Preferable one that sells clear corners, parking and headlights.
I'm not terribly interested in HID, but it would be nice to have a headlight that's compatible if i want to do it later on too.
Rollin Thunder
Va Beach Va
All headlights for the obs and up tahoes are compatible with HIDS. Its just the difference of doing it and doing it right.
You cant get a headlight that does both. Its either the HID headlight system posted. Or you get your glass headlights, and use halogens, Or put a kit in, but your beam wont be that good.
DJTricky
Banned
Robbinsdale MN
INFO FOR YOU ALL, putting an HID set in a car that did not come from the factory with hid's(system already installed) is illegal
its illegal to put the kit in any vehicle that did not come with hid's from the factory
that being said the housings are all the same unless they have the little bulb shield(its not a cut off shield(thats just on projectors)
that being said to that, i have 2 sets of hids in my truck 6,000K 35W Low beams and 8,000K 55W for my high beams,
why do we care if its legal or not, it looks good, and helps you see, so why not do it.
haks310
Got LEDs?
SoCal
I would care because I don't wanna be the dick blinding people. @#!% is annoying.
The TYCs are not glass, I also have them.
blkcam
underwater
Anyone know where I can get just the housings for the D1R bulbs?
I want to get the housings and hid kit separate so I can get 6000K or 8000K
I found a pair on ebay but the guy does not know if it is for d1r
haks310
Got LEDs?
SoCal
i dont blind people, i have mine aimed really low.
At least you did that, most people wouldn't care.
I know I've seen them on ebay before, try searching there.
Also, TYC makes 2 headlamps for the OBS, one is a halogen housing and the other one is a HID reflector one, so if it has the cup, that's the one.
blkcam
underwater
I have seen some that have the cup but do not have hid's. and they are cars that are straight from the factory
SuburbanPassion95
