PPV Tow/Haul setting?
All of you guys have 2013s and Powertrain Grade Braking should work in and out of tow/haul mode. Same with Cruise Grade Braking. Y'all also have Hill Start Assist too.
gpracer1
Phoenix
Yeah I have a habit of reading the manual front to back when I buy a vehicle. Never know what goodies you might miss out on.
gpracer1
Phoenix
My dad bought a used 2010 Mercedes S550 from an old lady client/friend that died last year, it has 26,000 miles on it and is showroom new condition. He is an owners manual non reader, and that car requires you to read it 8 times just to understand all the crazy amount of options and functions that it has. He calls all the time asking me questions......but it’s my dad so........
Sounds like my wife, daughters, mother, sister, aunt... LOL They won't read to save their lives!
gpracer1
Phoenix
Plus as an “ex” ASE master tech, none of my family ever goes to the stealerships to get their cars fixed....I do most of it, or at least troubleshoot it.
Ron C
Los Alamos, NM
I have to read it over and over and with my memory lately I might just discover something brand new!
same here, but not just memory. A few years ago I got my first "smart phone", took me half a day to figure out how to make a call. Also, bought a "smart TV" in January, didn't have a TV for a decade, took me two days to figure out how to change the volume.
Sure, could have read the manual, however nowadays those seems to have these pictograms and are not really helpful. Besides, not reading manuals is a social thing, else this forum would be quiet if everyone would read owners and shop manuals.
Ron
Ron C
Los Alamos, NM
my manual needed the actual stick added ... and the knob is blank... sorta like "if you're driving this thing, you should know what you need to do" *lol* T18 out of ford 1T pickup
PG01
Up here to the right
Wit granny low.....
Eod1
If you see me running, I would try to keep up.
Phoenix Arizona
Ok so I thought I might bring this back. So don't hate on me to hard. My question is when I add a tow bumper support from a SSV to my PPV and attach the 7 way wiring harness that was tucked up in the bumper cover do I need to add a brake controller or will the hoe see that I'm pulling a trailer and compensate for it and automatically apply the electric brakes?
PG01
Nope, need a brake controller
kbuskill
NE. FL.
You will need a brake controller.
You will also probably want to hook up the two red wires, that are hidden in the engine compartment, to the two studs on the front of the fuse box... assuming the PPVs have the two wires like the rest of the trucks do.
One should be taped to the harness between the fuse box and fender... the other should be taped to the harness under the master cylinder.
One supplies power to the pre-wired brake controller harness that is under the drivers side of the dash... again assuming the PPVs have this.
The other supplies power to charge the battery on the trailer for the break away switch.
Also make sure to add the fuses into the under hood fuse box to supply power to the two studs you attached the wires too.
Kee Fuller
las vegas
I wonder if i install the shift lever with the tow button on it and plug it up will the tahoe recognize it.
Eod1
Phoenix Arizona
Ok my hoe had those wires right where you said they would be. Now I'm looking for the corresponding fuses. You wouldn't happen to know the number s would you, and what thread pitch these studs are?
kbuskill
NE. FL.
Can't recall either off the top of my head but James @swathdiver can probably tell you.
Don't remember the threads, maybe Pete does. @Galante
It's those two J-Case fuses right in front of the studs. Not all the trucks are wired the same but in my manual they are 63 and 68. There are others like 6, 10 and 25 that power the controller, trailer back-up lights and trailer parking lights.
Skiroy56
