Tahoe Hybrid Transmission problem
Chicago38
I have a problem with the transmission. When I try to start the engine, the electric motor starts to rotate and I hear it, but the gasoline engine does not start. It takes about 10 seconds and it turns off. I checked everything fuel pressure 6psi. I checked all the fuses and the relay ,I restored the hybrid battery. I have no trouble code and I have new 12v battery. I climbed under the car trying to see if the flywheel rotates when I try to start the car, but as I saw it doesn’t spin, I can hear how the electric motor works.
I don t have idea what wrong now.
BG1988
Well STOP restarting it you will kill the hybrid battery
if you are only getting 6PSI at the fuel pump it's DEAD
what is the check engine light code ?? you clearly do have one as the Check engine light is on after starting as it turns off when cranking
I have a hybrid also ( so you cant' say it does not)
it's staying on when you are cranking the engine at 0:17
should be 50-65 PSI or so
Tell us the code buy a code reader that works yours clearly is broken
C
Chicago38
Sorry yes I have 60psi
So don't worry about my battery because I'm used Tech2 scan tool and charge my battery use Jump assist mode
My Tech2 not found any trouble code.
BG1988
well have you tired starting it with the remote?
but you have one though as the CEL is on
are you getting spark??
does it sound like the engine is spinning?... is the crank shaft moving(look under the hood)
if not then the transmission I/O shaft is broken
it's started by the transmission via HIGH speed 1500rpm start
and not a normal starter.. no normal 12v+ starter (they should have had redundancy though)
it's the one with the large pulley on it that would have connected to a mechanical A/C if was a reg one
if it's moving then you have a issue with the ignition system...
did you clean the engine or something before this happen?
did you do anything to the car before it happened?
this has a lot of tech info for it , you seem to be very technical
this will show you have to probe the correct wire to see if it has signal output when trying to start it..
http://www.atraonline.com/gears/2009/2009-05/2009_5_4.pdf
read the
Output Speed Sensor information
The error code you should be getting is P16F3,P2160,P077B,P0722... or similar
if possible,(and safe i.e flat land ) as soon as you start it put it in Drive so you can get your "check engine light"
C
Chicago38
read the
My crank shaft not move when I try to start engine.
Ep33401
