Aftermarket head unit swap in your PPV
RichardCranium
Mebane, North Carolina
Posted purposely in this sub-forum
Have any of you guys installed an aftermarket head unit into your PPV or SSV? I searched, all I can find in the last thread was @Ron C and his OEM/Nav swap. Not interested in that, specifically looking for a unit with internal BT and AndroidAuto, but more importantly looking to see what route you guys went with adapter harnesses, etc.
I think its safe to assume that no PPV came with Bose or Nav. Besides the antenna adapter, the only thing really needed to retain are the door chimes and in my case, steering wheel controls (I swapped wheels). Just seeing if anyone had any input on what they have used, if they were happy, or what route they would take if they had to do it all over again.
TIA
Kee Fuller
las vegas
I have the pioneer avic 7200 in my truck. I have the Metra ax-gmlan29-swc to retain my steering wheel controls. My truck still got the stealth mode so the door chimes dont work
if you have added the dic buttons then the chime volume control should be in the menu with a choice of high/med/low/off, unless it is somehow completely programmed out?
Kee Fuller
las vegas
I like it
Ilikemtb999
Denver
I also have a pioneer head unit. Originally had a PAC interface and it constantly cut out and buttons would work intermittently. I now have a maestro interface and it’s worked flawless. Also has a neat gauge feature. I replaced my door speakers when I got it due to them all being broke one way or another. Left the stock wiring.
badandyturbo
Florida
I have a Pioneer unit with a Metro harness. It retains the chime but through the adapter itself, not the truck speakers. I also rewired each speaker to an aftermarket amp.
Kee Fuller
las vegas
Yea i dont have that chime feature in my dic
RichardCranium
RichardCranium
Which head units do you guys have? Anyone use AndroidAuto?
Ilikemtb999
Denver
I have an avh-1300NEX with apple CarPlay. Works flawless. I know the higher end ones will do wireless now, unsure about the android version
tfi racing
Just added the button, and it is in the menu on my 2013, maybe the earlier years don't have that option.
Ilikemtb999
Denver
What wiring harness are you guys using?
RichardCranium
RichardCranium
Being you left the stock wiring and sounding like you did a basic (not high end) speaker replacement, you seem as if you are right along the lines for the same goal I am after. Better radio features and better sound than stock, am I right? I personally don't feel the desire to add an amp, I think I'll be content doing the same upgrade you did with a head unit/speakers only. My 2007 LS had the Bose option with the 6.5 woofer in the center console, I really was happy with how it sounded (better than standard, and mostly for low volume level listening).
If I am right in that assumption, would you do anything different with your setup?
Ilikemtb999
Denver
I’ve never been a “stereo” guy. I just wanted something with Bluetooth and CarPlay. I put pioneer speakers in that I think were $40-50 a pair and sound better than crackling or broken stockers.
I wouldn’t change a thing. Does everything I need for a budget price.
Perro
I'm using this head unit that I bought at best buy, it's not bad. My antenna reception is bad.20190705_193732.jpg 20190705_193800.jpg 20190705_193732.jpg20190705_193800.jpg
RichardCranium
RichardCranium
I'm using this head unit that I bought at best buy, it's not bad. My antenna reception is bad.View attachment 226430 View attachment 226431
Hope it works out! I contemplated buying one of the cheap Chinese radios with similar features to the top DD head units (for 200-300 bucks). That one is less than 100 bucks on Amazon, but it totes some really bad customer service and product reviews. With my luck I'll have all the issues, but hope it works for what you want.
The Whip
