mountie
I just received my new Coverking Dash Cover today. The no stitches / custom-molded.
I decided to order it when the sample-swatch I got from them was nearly a perfect color.
Well,.... There's good & not so good about it....
NOT SO GOOD:
1) The color swatch sample is a whole shade darker than the dashcover I received. ( The sample says " Poly Carpet Charcoal"....... The cover just says "Charcoal". )
2) The vent openings at the windshield are a 1/2" too close to the windshield, blocking a portion of the vent, there is 4 vent slits, 3 are showing. ( The dash cover is at the 'perfect' front edge of dash, where there is no room to move it forward. ( Plus, you can't move it forward due to window posts.
3) The dashcover end, at the right-side door, partially covers the upper part of the round glass defrost vent.
THE GOOD:
1) The moid/shape is very nice - matches couture of dash.
2) The dash mold & edges fit nice. ( You will barely need the Velcro to help fitment).
So...... I will contact Coverking next week. My thought is to use a Sharpie to mark the problem areas as it sits on my dash, and they re-do the cut, and send me another one.??????????
We will see....
Color Swatch middle.jpg Vent opening windshield.jpg Right door vent 2.jpg Cover edge at dash is good.jpg
HiHoeSilver
Away!
Chicago
Ok, lil help?
Can anybody find the nbs impact sensor on Amazon anymore? I see Dorman 590-200 on rock for $77. Used good condition OEM ( 10370149 or 15103522) on ebay for around $50.
Nothing on Amazon. Really?
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
GM#15103522 changes to new gm#10370149, i have one in stk for$262.95
just need ur name and cc#, lol
P0200 came back.
Get that new connector? I was looking at the soldering on that wire and it doesn’t look great IMO. Looks like either the wire was contaminated or not enough heat was applied. I’d get a new connector and make sure to cut some wire off the end of the old stuff so it’s good and clean, solder it good and use heat shrink tubing so it doesn’t corrode. You don’t want that to bite you at a bad time like in the middle of winter.
dizhai
