mwilson62000
Senior Member
Been driving me crazy that I hadn’t had time to give the Hoe it’s spring waxing. It was hot out today, but put her in the shade and finally got her waxed up.
Bart Hinder
Republic of Texas
on another note..... A 'jug' of brake fluid? I store brake fluid in a tea cup.
Flushing the brake fluid is high on my list, hence the jug.
It worked out. My first thought was to remove the reservoir and clean it out. Removed the battery and battery plate, and got nowhere. Evidently you need to remove the front clip to get it out. But I discovered the washer fluid lines have a connector, so I disconnected the rear line (and the rear wiper arm so it wouldn't be scraping a dry rear window) and used the rear pump to empty the reservoir into the now empty brake fluid jug (after reinstalling the battery). Flushed it three times using using a milk jug with dishwashing liquid and water (and cleaned the brake fluid off the fender).
I poured the now-contaminated brake fluid on a fire ant nest. Don't tell the EPA.
Think about what you're doing. Not what you're going to be doing next. I struggle with this.
Bart Hinder
Republic of Texas
Isn't an accidental 'mix'.. then becomes a name of a drink? :cocktail:
C' mon, everyone.... the weekend isn't over yet....
We used to go the the Airport Festival at IAH. They served
Pineapple Upside Down Cake. Vanilla vodka, Pineapple juice, and Grenadine.
Someone substituted grapefruit juice for pineapple. We called it "Sex on the Runway".
Good times!
Woodblocker55
Try this put coat of new finish wax ( polmar ) then coat of carnauba wax. It's amazing . Lots work though. And against waxing rules but works perfect. [emoji106]
Sent from my LGL84VL using Tapatalk
Merch619
