Adding an aftermarket radio to 07-14 FAQ
Bamajake95
Guys. I have the 2010 LT Tahoe and do not have the back up camera but i do have the parking assist. Upon shopping for a camera and options, I have moved to replacing the receiver with one that has camera options and apple car play, DVD, etc. This put me at Best Buy talking it over with a young guy that had most likely installed nothing but a steering wheel in a Lego car. The pc he used pulled up this list of things i would need to ensure all factory options would continue to work. RPS-GM31- PAC radiopro5 Radio interface, 40-CR10 Metra-Chrysler vehicle antenna adapter cable, AX-USB-Minib - Access USB adapter harness 2010 later vehicles, BBBPC - Metra Licence plate back up camera, AVH-2330NEX- Pioneer android autoapple carplay bluetooth in dash cd/dvd player receiver.
His words were, "It should work". So my concerns are..Will my parking assist and rear passenger stereo controls still work?
I have installed many stereos in my time but only had to worry about the antenna and rca jacks. This one may be outside of my field. The other thing is every time i have installed an aftermarket receiver, the FM stereo never sounds as good as the factory(cd and mp3 is great). Will this be the case in replacing the unit also?
Check into the idatalink maestro harness they are the best thing in my opinion and you can program what you want to keep and discard in the programming from the flash. However I'm 98% certain it will retain those features with all the needed accessories. Use idatalink maestros direct website.
Sent from my SM-G960U using Tapatalk
mattjones
VA
I have a 2011 Tahoe with Bose, nav system, backup camera and rear seat entertainment. I'm upgrading the head unit to a Pioneer with bluetooth and Apple Carplay and I'm trying to figure out what exactly I need to buy in addition to the head unit itself. So far I think I've got it down to:
-Wiring harness
https://smile.amazon.com/dp/B00B4PJ...colid=69XR9W83HEHP&psc=0&ref_=lv_ov_lig_dp_it
-Parking brake bypass (not sure if this is necessary)
https://smile.amazon.com/MicroBypas...23Y4Y7QVW7N&psc=1&refRID=1MBDCC7AE23Y4Y7QVW7N
-Backup camera retention harness
https://smile.amazon.com/dp/B00FY61...colid=69XR9W83HEHP&psc=0&ref_=lv_ov_lig_dp_it
-Rear seat entertainment integration harness
https://smile.amazon.com/dp/B00E3E1...colid=69XR9W83HEHP&psc=0&ref_=lv_ov_lig_dp_it
Is there anything I'm missing? And is the GM dash kit necessary if I already have the stock touchscreen unit?
From what I can tell, the wiring harness will retain all of the Onstar functionality and chimes from turn signals and whatnot, correct?
Bamajake95
Yes still have to have a dash kit even if you have a factory nav screen. Best thing to do is check metraonline.com for all your parts then search for them on amazon, or Ebay.
mattjones
VA
I'm on Metra's website and it shows everything that will fit a 2011 Tahoe but I don't really see a list of what I actually need based on my Tahoe's setup.
But like you said, I looked up everything I think I need on the Metra website and found them on Amazon. I posted the links above
Bamajake95
Get the 95-3305 dash kit, ax-gmlan29-SWC (provided you want to keep starting wheel controls) and call it done that harness will do everything you need and comes with the anteanna adapter.
Bamajake95
Also depending on what pioneer unit you have you may or may not need the video bypass. But the Metra ax-trig1 will work perfectly for what you need.
I bought my parts from Ebay from radioman621 they usually have good prices. Check them out as well. May save you a few bucks.
mattjones
VA
Awesome, so I don't need anything extra for the rear seat dvd entertainment and backup camera to work?
Bamajake95
No sir, that piece will retain both. But check out what all it does and make sure that covers everything you need for your application.
mattjones
VA
tun75
I have 2014 Tahoe, I am installing a Pioneer AVIX 5201 NEX, I have the idatalink Maestro and the harnesses. I have an adapter to plug into the harness and RCA to plug into the head. I can not find the vehicle harness for the camera (currently displayed on the rear view) or for the rear audio center. any idea where I can find these? I have search this thread and only saw where you need to splice in on a 2009. Thanks
Bamajake95
Go to maestro.idatalink.com and click acc. But the backup camera should be retained through the flash on the rr module.
tun75
I have been to there site and have all the guides. This is the vehicle connector I can not locate
Bamajake95
Which harness did you end up with? It should have been the hrn-rr-gm2
tun75
I have the hrn-rr-gm5+ ( no nav) I also have the hrn-av-gm5
Bamajake95
I should have a gm5 at work let me look at it when I get there.
tun75
Thanks, Appreciate it. So I am not confusing you I have attached a pic of what I have. The 2 black connectors are going to the factory harness that were plugged into the original radio. there is the gray connector that has 1 black wire going to the Pioneer and 6 RCA plugs (labeled from rear AV input, the other says to overhead screen) there is also a brown connector
with 3 RCA's (Center out, Sub out and Backup camera in) I am assuming I only need the gray or brown. I cannot locate a factory harness for these to plug into.
I assume the iDatalink will control everything except Video feed.
tun75
I figured out the AVG5 is just for rear video (which I do not have, just rear audio) now I just have to find where to tap the video feed to put the video for the camera to the Pioneer. it says pin 6&7 blue and white, I do not see those coming down the drivers A pillar.
mattjones
VA
So I installed my new Pioneer head unit today and it was a pain in the ass and honestly I’m not very happy with it so far.
Issues I’ve noticed:
-the door chime is VERY loud now. Irritatingly loud.
-my backup camera seemed to work at first but after I had the unit installed in the dash it no longer worked
-Apple CarPlay won’t connect
-DVDs won’t play on the head unit screen even when in park (I can’t press okay to acknowledge the Tahoe is in park)
-apparently there’s really no way to use the existing Onstar mic
I installed the Pioneer AVH 1300NEX utilizing the Metra dash kit and GMLAN29 harness along with a parking brake bypass because I figured “why not?” First off, it was damn near impossible to fit the harness and all the wiring behind the head unit.
I also didn’t have anywhere to attach these two cables on the new head unit:
I’m assuming the mini usb leads to the USB input in the center console. I could probably attach it to the head unit with something like this:
https://www.walmart.com/ip/Monopric...MInIbPtObO4gIVBYrICh0a3wxcEAQYByABEgIuqfD_BwE
I’m not sure what the blue adapter is though. Satellite radio? GPS? It doesn’t seem to attach anywhere on the pioneer head unit.
I had to jam all these cables in the opening in the back in order to get the head unit all the way in.
I think I may have knocked out the video-in cable trying to squeeze the unit in because the backup camera didn’t work when I tried it again.
I ran the provided mic through the lower dash and have the mic coming out right next to the bottom of the steering wheel. It’s not ideal but it’s mostly out of the way.
I’m not sure what’s going on with the dvd I tried to play. It won’t even let me press the ok button when it displays a message to remind me to put the Tahoe in park. I’ll probably remove the parking brake bypass and see if that’s the issue.
The door chime is incredibly loud. I don’t know if there’s any way to change the volume. If not the door chime alone might be a dealbreaker, which sounds crazy.
The biggest issue though is that I can’t get Apple CarPlay to work. That was the whole reason I got the unit. I’ve followed all the directions I could find and even though my phone connects to Bluetooth the CarPlay won’t connect. I could try connecting my phone to the USB input to see if that makes CarPlay work, but physically plugging it in defeats the entire purpose.
J
The chime volume should be controllable through settings. I know the Maestro module has a control but I don’t think you have that? Look in the manual for the Pioneer. As far as CarPlay, it has to be plugged in unless you have one of the very latest, few and far between, models that have wireless CarPlay. I just bought a Pioneer with it, AVH-W4400NEX which was the least expensive with the wireless feature @$500. Even new cars don’t have wireless CarPlay except a few BMW’s and such.
Edit: I have had to cut some of the plastic from behind stereos in order to make room for all the wiring if I can’t stuff it in the cubby holes.
mattjones
VA
Well damn, I thought Bluetooth plus CarPlay meant wireless carplay. Having to plug the phone in defeats the whole purpose. It’s nice to at least have Bluetooth now but for nearly $400 between the head unit and harnesses, etc, it’s not worth it. I’ll be sending it all back.
OldWYLawman
