Front bump stops
Dasanii19
Are my bump stops suppose to be this close? I recently purchased this 2007 Yukon XL 2500. The tire size the last owner has on this Yukon is LT275/65R18 and it does rub the front and back wheel wells when pulling out of the drive way at a turn. I’m just not sure if this is normal or if maybe the tortion bars aren’t adjusted right or maybe my springs are bad? Was hoping for some input. Thank you! Oh yea, my original bump stops were chewed up pretty bad, that’s why I replaced them.
Ilikemtb999
Denver
My 07 Sierra had z71 jounce bumpers (more pointy than those) and I lowered it down to where it just touched rode well. Originally though there was a small gap.
They’re not bump stops but rather a part of the spring system that adds progression to the system.
What does the rake look like on it? Any side shots?
D
Dasanii19
Ilikemtb999
Denver
That for sure looks too low in front. Obviously some rake stock but that’s far too much.
D
Dasanii19
How do I figure out if it’s bad springs or if the tortion bars just needs adjustment?
Ilikemtb999
Denver
I’d look at the torsion key bolts and see how far out they are. I’d just adjust them up some. Isn’t hard at all. Just make sure you go evenly side to side. Easier on the bolts if you jack the front end up but if nothing is corroded than you could just do it with it on the ground.
Ilikemtb999
Denver
Here’s my Sierra with the jounce bumper just touching the control arm up front and 3” lowering shackles in back
intheburbs
SE MI
View attachment 221312 View attachment 221311 Are my bump stops suppose to be this close? I recently purchased this 2007 Yukon XL 2500. The tire size the last owner has on this Yukon is LT275/65R18 and it does rub the front and back wheel wells when pulling out of the drive way at a turn. I’m just not sure if this is normal or if maybe the tortion bars aren’t adjusted right or maybe my springs are bad? Was hoping for some input. Thank you! Oh yea, my original bump stops were chewed up pretty bad, that’s why I replaced them.
I think the problem is the width of the tires. Mine came stock with 245 tires. Yours are over an inch wider, so I'm not surprised you're rubbing.
I'll get some pics of my stops later today.
You're forgetting that this is a 2500. That's pretty close to a stock stance.
Here's mine, stock tire size and stock suspension .
Actually sitting level, but loaded with 1600 lbs of people and stuff:
I think this illustrates the problem...
Ilikemtb999
Denver
My Sierra is also a 2500HD. Regardless I’d crank them up a bit to get less rake and less rub.
intheburbs
SE MI
A few more pics..
A better pic of the stock stance
And my shredded bump stop. If I actually had one intact, it'd be similar to the OP's.
So you want to trade off some annoying rub in favor of more stress on the CV joints, making them fail faster? No thanks.
I never understood that - whether it be leveling or a lift. You're putting more stress/strain on your power train for nothing more than a "look" or "stance?" SMH
Ilikemtb999
Denver
A few more pics..
Show me where a few turns of the torsion key bolts wears those out quicker. I’d also be running the correct size tires. (And on my own vehicle I actually lowered the front and the rear as I don’t care for the mall crawler look)
intheburbs
SE MI
If you're cranking the torsion keys to raise the front end, you're raising the axle height relative to the position of the wheels, which increases the angle of the CV joints. Bigger angle means more flex with each rotation of the axle. More flex means more wear.
I'm not saying it will lead to immediate catastrophic failure of the CV joints, but it will contribute to an overall shorter life, to some extent.
So again, why do it? I guess I'm just a function over form guy. It's a tool. I don't spend my weekends making my hammers and screwdrivers look pretty, either.
Hodmjstone
