Mooseman93
- Joined
- Dec 30, 2012
- Posts
- 37
- Reaction score
- 54
Okay heres a quick rundown on the issue.
2009 Tahoe SSV with the 6spd auto.
It had been parked on jackstands for nearly 4 weeks while i was getting everything together to to longtube headers etc.. etc..
While it was torn down i went ahead and dropped the transmission pan to install a new trans filter.
Last night i got everything back together enough to start it up and check for leaks and whatnot. While it was running I replaced the transmission fluid that was drained when the pan was dropped.
While it was still on the stands and running i figured i would put the trans in drive , reverse, etc. When i put it in gear there is nothing. It doesnt seem to go into any gear at all. No wheelspin or movement at all. Anyone else had a similar problem with their Tahoe? Any suggestions on what to check first. Ill check to see if there are any codes other that the emissions codes from removing the cats. Yes having it professionally tuned is going to be done this week , as long as it will go into gear and can be driven to the tuning shop. Im stumped on what has went wrong. I didnt unplug anything associated with the trans.
On the bright side it does sound Really GOOD.
I would start with a thorough review of the cable linkage. I know on my 01 Yukon XL it was a pain getting that thing out of the way to drop the pan and I actually damaged it in the process to the point that mine did something similar when I started it back up.
