Jeff Groves
Retired Demo Expert. I don't need to run anymore!
Nevada, Ohio
Got the new LED tail lights in. Had to chase down new screws as the stock screws wouldn't grab.
That involved dropping a can full of various screws and bolts down the basement steps. Looked like a frag grenade going off! Jasmine, my cat, was not amused and nearly tore the carpet off the steps in her hasty retreat!
Fastest I've seen her move in a long time! :happy175:
Jeff Groves
Nevada, Ohio
Thank Goodness for pre-emptive reading!
Saw a thread today that some LED tail lights would break the cruise control.
Just did a test drive and sure enough I need that fix. Now to find that thread again.
Knew I should have written down that flasher replacement number but I suffer from CRS at times.
Ahh! Found it! "Novita LM487 Flasher". Over $50 bucks ?????
I think the 6 ohm 50 watt resistors placed inline would be way cheaper!
Sam Harris
I got the flasher module, but you can use resistors as well, for each bulb.
I’ve been noticing the oil pressure in the 05 Tahoe I bought a couple months ago has been slowly dropping to around 20 at idle, going up to 40 when revved up. It still had 55% oil life left. Then today I noticed a tick at start up. Then it went away but when I got back from grocery shopping it was back. At 260 k I was thinking bad thoughts like a knocking rod. It didn’t sound like lifters, too slow of a knock. So I figured try an oil change and AC Delco filter and while the oil was draining I tightened a few loose exhaust manifold bolts. Knock is gone and pressure is back to 40 at idle.
Phew!
dszx13
Got the tune done today. The guy who tuned it said plenty left on table if I want it. Lol. My Yukon had flex fuel and I didn’t know it. Which is good because they have bigger injectors. Hopefully this posts correctly
Fosscore
So I had a straight through thrush muffler it was rediculously loud. So I bought this flowmaster 50 and had it welded on in is place. Funny story as the guy is taking off the old muffler he says I see why it might have been so loud in the cabin. The person who issued it put it on backwards. The V's were having towards the cabin. Is nice and quiet in the cabin now though so I am happy. And my twins can hear me without shouting. Lol
2004 Z71 Suburban Green I have a few upgrades done.
I have this same FM50 muffler on my 06.
Fosscore
That is a sweet sound indeed!! Nice one man.
brian.roberts.1293
Durham NC
Yes but that covers all with the module. You have to put resistors on every bulb as you put in LEDs. Like the flashers to stop fast flash fixed with module and the cruise fixed also. Just a little heads up.
Sam Harris
Holy shit. That’s awesome.
Sounds great!
Sam Harris
Hell yes! Nice work!!
PG01
Up here to the right
Sounds effin bad ass.
eand28
Pennsylvania
You’re lucky. Mine has the small injectors so I run out of fuel at 6500 rpm lol. Thinking about putting 8.1 injectors in it and getting it retuned
dszx13
I had a set from a nnbs set to the side just in case lol. At wot the injector duty was @ 79%
Very nice.
Martinjmpr
Littleton, Co
Not today but yesterday....
My '04 'Burb is a Tow Pig, and we spend most of the Summer pulling a 3500# trailer up and down Colorado's 11,000'+ passes. The trans tends to get a little warm, even with the factory trans cooler, so I finally decided to put on a bigger one.
For those who haven't seen it, here's what the factory trans cooler that comes with the "heavy duty tow package" on the 1500 Suburban looks like:
Not only is the "cooler" pretty small, it is almost completely hidden by the "bow tie" emblem on the grill, which means it gets very little air flow.
The old cooler came off pretty easy except for the lines. the lines are held in by little c-clips. I pulled the clips out but still couldn't get the lines to come out - may have been corroded or just stuck from 15 years of being in there. No worries, since I have no intention of re-using the cooler anyway, I just got a pipe cutter and cut them (note: Do NOT use a hacksaw as that could put little flakes of metal in your transmission!)
From a YouTube video I got the idea of just flipping the crossmember underneath the factory cooler to mount the new one. Worked like a charm! I also had to relocate the temp sensor for the outside temp display on the rear view mirror. Foam ear plugs are in the trans lines to keep debris from getting in there while I work.
Trans cooler bolted into place. I was able to attach it to the stock A-frame everywhere but on the top passenger side (left as you are are looking at the picture.) However, the kit comes with hardware including the steel strap that I used, so it's connected at all 4 corners. I used bolts for the lower connections and self-tapping screws for the upper connection.
Last step was to install the lines.
Because I don't want to risk kinks in the lines that could interrupt the flow of trans fluid to/from the transmission, I'm going to use some heavy plastic conduit over the trans fluid lines to keep their rounded shape. It will also protect the lines from damage. That will probably be done this week because our first camping trip is a week from this weekend.
You can see by the photos how much bigger the new trans cooler is. It should really help when we are climbing those high passes.
For those interested, this is the YouTube video that helped me out:
Escalade2007
